Old 03-22-2006, 03:15 PM
black beast black beast is offline
Back Road Blazer
Send a message via AIM to black beast
Car won't start, no wait its not that simple
Ok guys it seems that every time I post something cool it comes at a bad price. I instaled some STI ground wires (they look hott!) however to get to one of the stock grounding points (the tranny) I had to remove the intake pipe (and the MAF) Now the car won't start and I have done everything:
Cheaked the battery, fine
Cheaked the fuses, fine
Removed the wires and installed the stock ones, nothing
jumpstart her, nothing
Everything I try seems to lead me to one of two things:
a short, or the MAF has an override that I triggered and have not turned off. Please help.
-Chris
'94 ebony pearl, with orange "silicone" hoses, painted beauty cover, Tom's Intake, Dayles Cold air intake; with HKS mega suction foam air filter, 3in header back exhaust, STI ground wires, euro front fascia, euro front grill, reactive 17in wheels, Nitto Invo's, Drilled and slotted rotors, stainless break lines, Koni strut inserts, Drop springs, 5MT, shotshifter, Clutchmasters clutch, ACT prolite flywheel, EL Glow gauges, The ECUTune stage 2. To Do: Cams, port and polish, etc.
Old 03-22-2006, 05:12 PM
Explain the exact symptoms you are getting while turning the ignition to on/start.
You turn the key and....... 'what' happens? What kind of nothing?
Did you plug your maf back in?
Old 03-23-2006, 05:44 AM
intelisevil's Avatar
<<<Alcyone
Did you hook the ground wires up to the positive battery terminal?
No, I'm sure you would have noticed the bright flash . . .
Dan
Old 03-23-2006, 01:09 PM
Do you have warning lights or interior lights or is everything dead?
Did you check the fusible link in the fuse box under the hood? Do a search for "fusible link" and see if this helps.
Old 03-23-2006, 06:43 PM
Back Road Blazer
Nothing like nothing, no sound no lights no ding ding ding when I open the door no door panel lights no nothing. I have checked all the fuses but what is this fusable link? All the fuses are fine is that what you mean??
-Chris
Old 03-23-2006, 08:08 PM
Speedklix's Avatar
Locker Link Solution
There is a fuse box under the hood. Open it and see if the white rope thing with black insulation at the base of each end is in tact. That is the fuseable link.
If it is broken, only replace it with a new fuseabe link, don't play around with it. Do it with the battery disconnected.
I feel like I am forgetting something here...
-Mike
[SIGPIC][/SIGPIC]
Catch you next at: ? Auto-X ?
Old 03-23-2006, 08:28 PM
The fusible link is located on the right side of the fuse box in the middle. See diagram. The part number is 82301PA000 and they run about $5.00.
I always keep a spare one of these in case of emergency.
Old 03-23-2006, 08:39 PM
Speedklix's Avatar
thats it... and before you replace it make sure all your ground wires really are connected to the correct ground points. Don't connect any of the upgrade wires to the alternator.
-Mike
[SIGPIC][/SIGPIC]
Old 03-23-2006, 10:59 PM
I have performed maybe a dozen of the alternator wiring upgrades. In all that time I have never had a problem and have never disconnected the battery before doing so.
I remember doing three of them in a row at the 10th Anniversary meet this way. If you are careful and don't cross or short cables you should be fine.
