Old 03-16-2006, 07:26 AM
Antigenus's Avatar
Antigenus Antigenus is offline
Send a message via AIM to Antigenus
Transmission Tweak via Resistor on Battery??
I read somewhere, and have the instructions printed out around here somewhere, oh here we go I have the instruction and I will paste them.
"After listening to all the opinions about why they hold up so poorly, I came to the conclusion that the number one cause of premature failure in the SVX automatics was the slow shifting. During shifts, the bands and clutches inside the unit have to slip a certain amount when they engage the next gear. How much slippage occurs has a direct effect on the amount of heat produced as well as how much wear results from each shift.
Many owners have discovered a little trick to firm up the shifts by unplugging the resistor that moderates the line pressure. This resistor is located behind the battery and when unplugged, results in firmer shifts at virtually all speeds. Unfortunately, two side effects are too firm shifting at low speeds and hunting of gears on deceleration. "
Does this seem like a reasonable tweak to try? I have a brand new tranny that was replaced, not rebuilt and I want to savor the transmission as long as possible and get a little firmer shifting...could this work? Anyone do this before? Let me know what you think.
Matt - Akron, OH
And then what???
Old 03-16-2006, 08:13 AM
Myetball's Avatar
Myetball Myetball is offline
Mr. Inappropriate
Don't disconnect the resistor. What you want to do is install a shift kit from Smallcarperformance. BTW, the guy at smallcarperformance wrote the info you posted above but goes on to explain further HERE.
Old 03-16-2006, 08:17 AM
Ricochet's Avatar
Ricochet Ricochet is offline
I brought some ham.
wtf is that? some hose and zip ties for 45 bucks???
Brian
Old 03-16-2006, 08:36 AM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Check with SVXFiles for a much less expensive "fix" for this...
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 03-16-2006, 10:22 AM
Antigenus's Avatar
Is this even necessary? I mean is this only applicable when you are encountering issues with your tranny? I'm not really into modding this if its not a complete positive effect to the operation of the SVX.
Matt - Akron, OH
And then what???
Old 03-16-2006, 11:14 AM
Don't unplug the resistor. This will generate an error code in your TCU. You will never know if there are multiple errors being reported unless you check the codes every time you get in the car.
Old 03-16-2006, 02:38 PM
Myetball's Avatar
Mr. Inappropriate
Kinda confused as well, disconnecting the resistor is not completely positive. You get firmer shifts yes but all the time, even at low speed and the tranny will not downshift properly.
"Ricochet wtf is that? some hose and zip ties for 45 bucks???"
Now there's a well informed question.
Since the link I posted may have escaped some of you, here's some more info:
What if my transmission seems to be working perfectly?
If your transmission seems to have no problems shifting or has been rebuilt recently, you may not notice much difference in normal driving. Even so, under brisk acceleration the Smallcar kit will firm up the shifts, helping your transmission last longer.
What if my transmission has problems?
If your automatic shifts sluggishly or has other problems, try unplugging the resistor behind the battery. If this seems to generally improve the operation, the Smallcar shift kit will help. If not, it's probably time for a rebuild or a Smallcar 5 speed.
How does it work?
The kit uses manifold pressure to sense engine load and switches the line pressure higher or lower as needed. For those who like to tinker, the switch point is adjustable.
Old 03-16-2006, 03:22 PM
Antigenus's Avatar
Thumbs up or down on this?
Matt - Akron, OH
And then what???
Old 03-16-2006, 03:43 PM
AppStateSVX's Avatar
AppStateSVX AppStateSVX is offline
Mountaineer
Send a message via AIM to AppStateSVX
do a search on this subject if you want a lot more info. There has been a LOT of talk about this, and some possible bad effects on the differential...
1992 Midnight Black LS-L - Sold 3/3/06
1991 Toyota MR2 - Sold 11/27/07
1992 BMW 325i
- Tokicko Suspension
Old 03-16-2006, 04:29 PM
Antigenus's Avatar
That was the answer I expected to hear from a politician haha just kidding
Matt - Akron, OH
And then what???
Old 03-16-2006, 04:50 PM
AFBeefcake's Avatar
Subaru Swapper
and a vacuum switch. Which is what makes the whole kit work.
I've had the kit on my car since it was first released by smallcar. I like the kit. My shifts are much firmer and there is no hunting on down shifts.
2005 Legacy GT
My WRX's Cardomain Page
Old 03-16-2006, 06:03 PM
Thumbs up.
Old 03-16-2006, 06:24 PM
Originally Posted by oab_au
Thumb up.
hehe...fixed
Old 03-16-2006, 06:42 PM
Originally Posted by Earthworm
hehe...fixed
OK smart ass, I used the same thumb twice.
