Old 03-04-2006, 11:23 AM
demonsvx's Avatar
demonsvx demonsvx is offline
building more AK47's
Angry Legacy-fixed timing belt now what
Ok So I replaced the timing belt per requirements and now my car wont idle when it warms up, it idles fine with no missing when its cold but as soon as the thermostat opens up thats when it dies and wont stay running unless I keep in the gas.I also replaced the FPR as I thought this was my original problem. All spark plugs are firing and are dry, no oil or fuel but a couple of them are black and sooty not white. Any suggestions would be helpful
1992 SVX LSL Ex wifey has it now pending self destruction 2001 Legacy mods to come 1992 Subaru Legacy 2.2 214k Boob wheels CANT KILL IT
Old 03-04-2006, 04:33 PM
I would seem to be rich. Ok when cold, too rich to idle when hot, black sooty plugs, suggest this. Are the affected plugs on the same side as the vacuum pipe for the FPR? Is the FPR the same pressure as the orignal.
Old 03-04-2006, 04:43 PM
demonsvx's Avatar
Same motor and FPR but the plugs are sooty on that side so what can you tell me?
Old 03-04-2006, 05:44 PM
svx_commuter's Avatar
It could be the coolant temperature sensor since it happens after it warms up.
SuperbVehicleXtraordinary
Proud sponsor of a 1992 SVX.
Old 03-04-2006, 10:43 PM
Manarius's Avatar
Manarius Manarius is offline
Replace the Coolant Temp Sensor. It'll fix your problem.
-Jason
-Obi Wan Kenobi
Old 03-05-2006, 09:51 AM
demonsvx's Avatar
Ill try the coolant sensor next. Thanks for the quick responses
Old 03-06-2006, 01:40 PM
Hopefully the timing belt was aligned correctly and didn't jump a tooth.
Old 03-06-2006, 04:48 PM
demonsvx's Avatar
Im starting to think that Ive jumped one tooth on the timing. Ive changed the coolant sensor and nothing changed. Can it being one tooth off affect it that much?
Old 03-06-2006, 05:07 PM
Usually no but who says it's just one tooth?
Old 03-06-2006, 05:12 PM
demonsvx's Avatar
I hope its the right timing belt Advanced auto parts you know
