Old 03-07-2006, 10:48 PM
Originally Posted by Kaline
I used to be an engineer at a major U.S. tire company, and all I will say is if it helped the tire perform better, it would be designed into the tire! My opinion is that siping is pure profit for the tire shop, accelerates tire wear and give less dry and rain grip.
If you were an engineer, than you know that some tires have the small cross cuts in the tire when they are made so that they do have the better properties if traction and cooling.
Old 03-08-2006, 05:37 AM
dcarrb dcarrb is offline
But Earl, the critical factor here is that tires that come "siped" from the manufacturer were designed that way, not arbitrarily altered by a retailer who probably knows next to nothing -- technically speaking -- when it comes to tread design and tire construction.
A quick Google search brings this, from a page called "DIY Tire Siping:"
"I will described what I did to my tires. I think they work better after siping and I've had no problems with it. You should be aware that siping tires may void your tire warrantee, whether you do it or a shop does it. The Rubber Manufacturers Association, a trade group representing tire makers, neither endorses nor condemns the procedure. It says that it is critical that siping be done properly to avoid ruining a tire.
"Tire makers have stronger opinions: Goodyear Tire & Rubber Co. does not recommend that passenger tires be siped, because the tread depth and the tire body are not designed for siping. Siping could invalidate the warranty if Goodyear determines that a tire failure was caused by the procedure.
"Michelin Tire (who also market the popular BFG brand) does not recommend it, but acknowledge that it is common in the industry. Siping can alter or corrupt the design criteria that were established for that tire. It can cause excess noise, excess heat buildup, and it could ultimately cause damage to the tire. (e.d. This last statement is interesting as these are some of the benefits of siping large monolithic tread block)
"Also, you should check your state vehicle codes, some states (like VA) do not allow siping tires, at least they will not pass a vehicle inspection.
Certainly not the definitive word, but food for thought.
EDIT-- Here's a straightforward news article on siping (which I didn't get the option to name):
http://www.komotv.com/stories/40020.htm
dcb
Old 03-08-2006, 07:43 AM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
Originally Posted by dcarrb
From that article:
If a consumer has a concern about grip, he said, they should look [for] a tire that matches their needs, rather than trying to alter the treads on the tire they selected.
Sums it up nicely I think.
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
Old 03-08-2006, 08:54 AM
svxash's Avatar
svxash svxash is offline
Hey I found this link on siping.
http://www.sipers.com/videos/Holland_Edits-DVD.wmv
Looks interesting.
1997 Boudreaux LSi
1994 SVX LSi(SOLD)
Kool Blue air filter, 4500k HID's, airbox mod, Hella horns, WRX 6 disc stereo, Infinity Reference and Clarion Pro Audio speakers, Infinity basslink sub, ECUtune Stage 1v5, ECUtune TCU, Power mode mod, Mad muffler mod v1.3
