Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Brake Upgrades
Old 02-26-2005, 01:30 PM
Rotorflyr's Avatar
Yet another brake pad thread
Ok, so Im ordering rotors and stainless lines and I was planing on going with the Akebono ProAct's but am wondering if I should save the $46 and go with the Axxis Metal Masters......
Has anyone here used both of them? Which did you like better?
Let's here some opinions!
2006 B9 Tribeca
Old 02-26-2005, 01:41 PM
sxewhodey's Avatar
sxewhodey sxewhodey is offline
metal masters?
You probably know but I just wanted to make sure you dont order metal or and semi metallics if your rotors are slotted or drilled. It totally burnt my rotors up and squelled like you wouldnt believe. Im trying kevlar next, and then Il go to ceramic if those dont work. Kevlar was only half the cost so Im gona try them.
Old 02-26-2005, 03:24 PM
Rotorflyr's Avatar
Mike,
Hadn't heard that actually, and iirc, there are some members who are running them Metal Masters without a problem.
Could it be that your rotors were already bad and this caused the problems you had??? (I've never used Metal Masters or Akebonos)
Also it was good meeting you and the family.
2006 B9 Tribeca
Old 02-26-2005, 05:55 PM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
Re: Yet another brake pad thread
Never had the ceramics, but I have the Axxis on my car right now and I love them. After break-in, dusting has been very low and braking performance with the Race Concepts slotted rotors F&R is excellent!
-Chike
2006 Steel Gray WRX TR (sold)
Old 02-26-2005, 06:32 PM
Weasel 22
EBC Green Stuff!!!
Old 02-26-2005, 06:46 PM
sxewhodey's Avatar
wow
Well I had some semi-metallics on their and they were ground down in two months. Thats just what the brake shop was telling me(that you cant run metal pads on slotted rotors because the slots take heat away from the rotors and return it back to the pad, which metal cannot stand the heat and something such as ceramic could absorb the heat and not squeel). My Rotors were all brand new but maybe the metalmaster is just a better brake pad? That was just the exp;anation I was given and it sounded logical so I went with it.
Old 02-26-2005, 07:19 PM
Chiketkd's Avatar
Re: wow
I haven't noticed any squealing or even 'squeeking' from my semi-metallic pads.
-Chike
Old 02-27-2005, 12:52 AM
deruvian
I've got the Akebono ProACT pads. Front and rear, slotted zinc-coated rotors in the front, OEM rotors in the back. I am amazed with their performance. They do not squeek, there is literally zero brake dust residue, and my GTech reports a decrease of a couple feet in braking distance.
I highly recommend them, but they are expensive. If you have the money, I would definitely get them. If not, the Axxis pads are a good second choice.
Old 02-27-2005, 06:10 AM
Rotorflyr's Avatar
Thanks to those who have given their opinion already!
Anyone else??
2006 B9 Tribeca
