Old 09-27-2004, 08:23 PM
scottsubarus's Avatar
scottsubarus scottsubarus is offline
Scottsubarus
speedo quit...easy way to pull codes??
What is the laymans way to pull codes to see why speedo quit al of the sudden.
Old 09-28-2004, 03:07 AM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
Here's the instructions to pull the codes.
http://www.subaru-svx.net/photos/user.php?How-To|14264
There will only be codes if your "Check Engine" light has come on.
If your speedo has quit and your CE light is on then the problem must be speed sensor #2. That's the sensor which drives the speedo (and several other things).
If your CE light is not on, then the ECU is still getting a signal from the sensor, so the problem is more likely to be at the speedo end.
There's some information about speedo problems in the HowTo folder.
Phil.
Old 09-28-2004, 08:57 AM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
If your speedo quit, it's highly likely that the plastic piece going into the top of the trans threw in the towel....hope this isn't the case! (i.e. you have to pull the trans to get to it)
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 09-28-2004, 11:05 AM
Peach
no speedo
When my speedo quit I got lucky. Not wanting to believe a speed sensor or such was bad, I cleaned and wiggled connector at speed sensor. Next I unplugged the two big black connectors on top of tranny and took a pair of fine needle nose pliers and slightly moved the male pins. Sometimes there is dielectric grease in the connectors, anyway I replugged everything and my speedo started working again, whew. I realize this is the simpliest scenario tho.
Old 09-29-2004, 01:46 PM
Scottsubarus
Wierd. some days the speedo works fine, then without warning it deciedes to take a break and quit for a while......what would that sound like. Its hard to ck something when its working....
Old 09-29-2004, 03:16 PM
nsm484's Avatar
nsm484 nsm484 is offline
Teh Geek
Send a message via ICQ to nsm484 Send a message via AIM to nsm484 Send a message via Yahoo to nsm484
Sounds like when I first got my SVX... cept it was alittle different...
I will explain in Detail... so mabey SOMEONE can give me a clue...
When i first got the SVX... As long as I was Accelerating... I had a Speedo Reading, I let off the gass, needle droped...
this continued for about 3 weeks... then it started to be intermit..
it would read my speed when IT wanted to...
then it finaly died.... However... sence I got used to knowing my speed via my RPM's.... I reset my Trip sence I wasnt paying much attention to that side of my dash anymore (unless I was low on gas of course)
Sence 2 months ago... my Trip, just yesterday, read 22miles...
so in 2 months... of driving darn near everyday..... it has shown up only 22 miles... i saw this a few times... out of no where the needle would jump up to my speed for a sec... and dead again...
Is this an electrical problem? I took my intake Pipe off yesterady
and made sure the connector of Sensor 2 was on there good... it was... I even looked realy close at the Male pins inside the top of Sensor 2... looked fine
(that hurt trying to hold myself up and look close at them too... my girl actualy had to hold my feet as I was balancing on the side of the car LOL)
I also checked the connections going to the ECU... un/repluged everything... still nothing... so at this point I think its just dead....
or is there anything im missing
(and yes... the ECU Says Sensor 2 when I pull codes.. along with both my Oxy Sensors... but im not to worried about them ATM)
-Roger H. | Website - nsm484.com | Facebook - Roger Harvey | Twitter - nsm484 | Personal Locker
2002 Mitsubishi Lancer OZ Rally [Nori]
1996 LSi Polo Green [Calista] - 18" Konig Incident's - Lived for awhile Now Selling
1992 LSL Dark Teal [Yori] (Rear Ended, Donor to Calista, and now gone)
1992 LSL Ebony Mica (Sold to svxcuseme)
Old 09-29-2004, 05:29 PM
It's the sensor itself...not the connectors. I think the most common problem is a plastic gear that breaks inside. If you search you should find more info on this.
Old 09-30-2004, 12:55 PM
Scottsubarus
OK, going to just replace the #2 sensor.......problem is subaruparts.com doesn't show that you can just buy one or the other sensor. It shows to come as a assy...(both sensors) does anyone have the part # for just the #2 sensor????? I don't want to buy both to get just the one I need. Just so I understand, the #2 sensor is mounted OUTSIDE of the case, and sensor 1 is the one inside the case??
Speedo works most of the time, but when it quits the ck engine light comes on
