Old 09-23-2004, 09:06 PM
Shadow248 Shadow248 is offline
Rep from the outside world
Send a message via AIM to Shadow248
It does even out though. AWD vehicles are significantly heavier. So when it comes to racing, vehicles have their advantages and their disadvantages. Ever try putting slicks on all four tires? That would be something eh? Or even just drag radials. You may be shopping for a new transmission (or diffs if it's a manual) after you try it.
Old 09-24-2004, 06:38 AM
solarsvx solarsvx is offline
Send a message via AIM to solarsvx
wow shadow you have much to learn.
my car weighs exactly 3,080 wich is not heavy and not a light weight honda ether
the sti and evo 8 both weigh in at 3,250 i think wich is still lighter then any american v8 car
the new gto weighs 3,600 lbs i think the mustang 3,500 lbs
so its true AWD does weigh alittle more then a 2,700 si or 2,800 srt-4 but still a lot less then you american v8 muscle cars
2008 evo x with sss package
430 hp 380 torque stock turbo with basic bolt ons
12.56 @ 109 fully weighted 3,500 lbs
Old 09-24-2004, 07:23 AM
GreenMarine's Avatar
From POST-***** to LURKER
Re: Re: Re: Re: new wrx time. o/t
Originally posted by Chiketkd
You'll need to read the MotorTrend article: EVO vs STI thread in its entirety. Landshark and Shadow have been dueling back-and-forth...
-Chike
Hehehehe, I know.... I joined in the battle, Just because I hate it when GM lovers try to tell us that GM's products are actually good products.... GM got where they are today by producing the muclecars and trucks that they always have, not by producing cars that are a pleasure to ride in... I just wish people would understand this
Old 09-24-2004, 07:27 AM
Originally posted by Earthworm
What about:
AWD cars can launch harder than RWD cars without losing traction. This would not include using slicks. I've run my dad's 1969 Nova SS w/ 5.12 rearend and slicks to a 13s 1/4 with a trap speed of only 100mph. The car is a beast out of the hole!
But my real question is that, if they "get outta the hole" quicker, shouldn't they be moving faster at the same point (say.... 1/8th mile down the track) that a RWD car or FWD car??
Can ya tell, I'm not a big fan of dragracing... I don't know jack about it
Old 09-24-2004, 11:13 AM
Not necessarily. The RWD car will need more power going to the wheels to catch the AWD car in the top end.
Old 09-24-2004, 11:22 AM
My fully loaded WS6 is just under 3500lbs. It's also a foot longer, 6 inches wider, has double the number of cylinders, and tires as wide as your driver's seat. That's not a great comparison.
The base Z28 camaro (LS1) weighs in around 3100lbs. That's actually a much better comparison because it carries nearly the same "options" as your WRX. But it's still much larger and manages to be not much heavier.
The GTO is a pig...3800lbs commonly equipped.
The RWD car has more power to the wheels to begin with due to alot less driveline weight.
Old 09-24-2004, 11:26 AM
i would like to see proof of this??
only extra driveline in a RWD to AWD car is 2 extra axles up frount , whats your pointe here? what extra weight is there?
Old 09-24-2004, 11:35 AM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
Originally posted by Shadow248
[B]The base Z28 camaro (LS1) weighs in around 3100lbs
All the info I've seen has the curb weight for the 'stripped-down' model closer to 3250lbs...
-Chike
2006 Steel Gray WRX TR (sold)
Old 09-24-2004, 02:00 PM
Of course. Only problem is that I don't know of any resource that gives info that detailed about weight differences between trim levels, etc. I could show you proof on LS1tech, but you wouldn't believe that anyway.
two extra axles and joints, front diff, front driveshaft, a transmission that weighs almost twice as much as a 2WD counterpart, and all the associated electronics and solenoids necessary to run the system. Yeah not much.
Old 09-24-2004, 04:40 PM
due you have serous issues,
2 axles, a spider gear does not weigh much, what drive shaft ?? same thing a RWD car has,, what selnoids?? im still dont know where u are going here,
2axles and joints,,thats all folks
i would agree it weighs alot more then a FWD tranny but almost the same as a RWD tranny
a RWD tranny weighs just as much as a AWD tranny.
have you even seen a subaru transmission ebfore u start talk **** that you have no clue abought again ????
do your research liek a good little boy then come chat with me,,
as for a 3,100 camaro z28 f-body,, unless i see prove its your worthless word, so i urge u to prove me wrong,
Old 09-24-2004, 09:48 PM
Originally posted by svxsubaru1 in the other thread
...all it said was if you lift off the gas thr car goes into a slight under steer, probley due to the front diff. The front diff on the 05 Sti was replaced...
One of you is wrong. And yes, the AWD tranny is significantly heavier than even a RWD tranny. Period.
You talk all day about my car and other GM cars that you have no clue about. I came into this thread complimenting you and this is what I get? You really have some inferiority complex. Forget it then, if you can't act like a big boy, then just take your little kid car and play with the little kids.
Old 09-24-2004, 09:58 PM
BoondockSVX
No. AWD cars have less drivetrain loss. If you have two identical vehicles, with the same engine, and the only difference is one is AWD, the other is RWD...the AWD will be able to beat the RWD one in 0-60 times, but the RWD will catch up with the AWD one and pass it.
Why?
AWD cars lose about 30% of their engines output to the transmission. RWD cars are more like 15-18% loss. This means at the wheels, RWD cars have more power. More power means more go. AWD just provides superior traction.
- Jim
Old 09-24-2004, 10:01 PM
BoondockSVX
AWD cars have these disadvantages:
1. AWD systems take up more room and weigh more.
2. AWD is not as efficient, it puts less power to the ground than RWD or FWD.
3. AWD has a LOT more rotational mass.
#3 is important. If you put big heavy 20" chrome rims on your car, it will feel a lot slower. Why? Wheels are basically big round continous levers... and the more MASS you have on these 'round levers/wheels', the more power is required to spin them up quickly. AWD cars have TWICE the driveshafts to spin up, twice the wheel mass, etc etc etc. Everything a RWD car has to spin up, but times two.
- Jim
Old 09-24-2004, 10:06 PM
BoondockSVX
You need to learn what rotational mass is. Rotational mass is the reason people want lightweight flywheels.... lighter driveshafts, etc.
- Jim
Old 09-25-2004, 09:06 PM
Chiketkd's Avatar
Shadow, I'll add this point to the discussion:
The weight of an AWD auto trans varies greatly from the weight of an AWD MT.
An AWD SVX 4EAT weighs ~230lbs (shipped my stock SVX 4EAT to a guy in Chicago). Mychailo after doing a 5MT swap, noted a weight loss of ~100lbs, most of which was due to the different trans (i.e. no torque convertor, TCU, etc).
Therefore, this puts the weight of a 5MT Subaru trans somewhere in the region of 150lbs. From owning a '95 Camaro, I know for a fact that the 6MT trans weighs much more than that figure (>200lbs).
Now 6spds in general weigh more than most 5spds, but the additional 80+lbs your WS6 is carrying around from having six forward gears is equivalent to added weight of the awd drivetrain on a 5MT car.
-Chike
