Old 07-30-2004, 11:04 AM
mhl0125 mhl0125 is offline
Send a message via AIM to mhl0125 Send a message via Yahoo to mhl0125
Power Steering issue
When I cold start my car, the power steering squeals and it is difficult to turn. If I try to turn it sitting still, all the idiot lights come on. After 30-45 seconds of driving, all of the noise disappears and the steering is flawless. There are no leaks, the fluid level is full, and there is a new "O" ring on it. Does anyone know what causes this and is there a fix? Thanks. The belts are also new.
Michael
1994 Barcelona Red SVX-LSI
Two-owner:169K
1995 Emerald Green SVX L AWD
#80 - Custom intake w/cone filter
99K with killer stereo system
2002 Acura MDX-Touring Edition w/navigation
2008 Toyota Prius
1987 Mercedes Benz 560SL
Old 07-31-2004, 04:23 PM
n00b on demand's Avatar
The car does alot of things when it is cold....i have issues with mine on cold start but when it warms up everything goes away and it runs perfectly.
Old 08-01-2004, 07:28 AM
Thanks for sharing. I can't ffigure it out, unlrdd the PS steering fluid doesn't circulate for a minute or the belts need a minute to warm up and expand. I would love to know what really goes on.
Michael
Two-owner:169K
2008 Toyota Prius
Old 08-01-2004, 11:13 AM
TorG0d
Mine does that ever since I put PS fluid in the PS reservior, cause we all know our SVXs use ATF for power steering and PS fluid is BAD for our cars.
Old 08-04-2004, 11:23 AM
The problem is not with the power steering. It is most likely your crankshaft pulley has separated. Either that or the belt is just not tight enough.
Old 08-04-2004, 03:23 PM
Thanks. I'll check out both and let you know.
Michael
Two-owner:169K
2008 Toyota Prius
Old 08-05-2004, 07:31 AM
dcarrb dcarrb is offline
Using "power steering fluid" instead of ATF isn't likely to cause trouble. I agree with Earthworm that it's a belt/drive problem, as the illuminated warning lights would indicate that the alternator is likely affected. When you start the car, these accessories simply aren't turning as fast as they must for proper operation.
dcb
