Old 07-23-2004, 08:08 PM
nsm484's Avatar
nsm484 nsm484 is offline
Teh Geek
Send a message via ICQ to nsm484 Send a message via AIM to nsm484 Send a message via Yahoo to nsm484
(Tranny) Cant run in 3rd?
Ok... heres the story
After reading many many many things on here about riding
in 3rd under 60mph... i thought that was a good idea... and
tried it myself.......... To my Dismay ;(
Driving in 3rd... no problem... But I cannot let go of the gas:
Once I stop holding the gas, like when i want to slow down alittle without hitting the brakes. insted of slowing down normaly...
it acts as if its in Netural... RPM's go down to around say 750-700,
then it revs up and you can feel the tranny catching a gear, then repeats the loop the entire time my foot isnt on the gas in 3rd.. I tried this also in 2nd, no problem, and 1st, no problem...
only seems to be a problem in 3rd, and it defantly doesnt do it
in D eather.
Now appon reading other tranny threads... there was talk of the
brakebands in the tranny, where if to tight (i think?!?!) that it will feel as if you hit the brake as the tranny shifts gears... My car does feel like this, under certan acceleration circumstances....
Could this be the cause of my weird 3rd gear problem?
or is my Orig Tranny just about to go?
Note: I dont drive durring the day much, its mostly an eve/night driver, sence I work overnight. The hotest part of the day it sees within the last 2 weeks is dusk... so atleast its not getting this
nasty Muggy Daytime Florida heat!
Any reply would be helpfull as im totaly confused as to whats going on... and almost afrade to adjust the brake bands, as the thread i was reading said it was a super sentive adjustment.
-Roger
-Roger H. | Website - nsm484.com | Facebook - Roger Harvey | Twitter - nsm484 | Personal Locker
2002 Mitsubishi Lancer OZ Rally [Nori]
1996 LSi Polo Green [Calista] - 18" Konig Incident's - Lived for awhile Now Selling
1992 LSL Dark Teal [Yori] (Rear Ended, Donor to Calista, and now gone)
1992 LSL Ebony Mica (Sold to svxcuseme)
Old 07-23-2004, 08:14 PM
tancred
No idea man, as long as when you floor it and it doesnt bog and slip or Power Mode isnt comming on and staying on, then i wouldnt be too worried, i plan on killing my 2nd tranny here soon so i will let you know how it acts when it begins to die..
Old 07-23-2004, 08:27 PM
nsm484's Avatar
Teh Geek
Another thing that happened a few days ago.. as I was getting
on I-95 to head to work... There was alot of traffic, so everyone getting on the Interstate from that enterence was going 5-10mph?!?!?!? Anywho... one I got an opening, I floored it, and got
the good ole raction... it just went! then an IDIOT changed lanes without signaling and got infront of me and I had to let go of the gas RIGHT BEFORE I hit 2nd, and after i let go of the gas, it made a huge "THUD" into 2nd gear... all i could do was cringe at the
sound that it made... I havent done any major accelerating sence then... cause that also realy bothered me ;(
Old 07-23-2004, 08:48 PM
tancred
My differential is making a THUD when you accelerate then let off fast, its like it wanted to hit the next gear but had to settle for staying in the current one. I have had 1 tranny go from good to bad on me, all my fault aswell. The beginning signs of my tranny going out was the slippage, later on, when going uphill it wouldnt even want to grab in gear. Finally it would randomly go in and out of power mode, and power mode would stay on and never come off, which was kinda fun to drive like that but...My advice, leave it in D, dont jack with it, I used to shift my auto everyday, from 1-D i would downshift and abuse it. I promised myself with this new SVX that it would be in D exclusively.
The THud could be a lot of things, I think my current tranny is on the way out the door or my differential is...it grabs, then lets loose, just cruising around town. Until the engine gets up to temp. So I would advise maybe check the DIFFs....the clunk/thud is most likely a diff....
Old 07-24-2004, 01:01 PM
nsm484's Avatar
Teh Geek
Anyone else have an idea of the problem im having, or have had the same problem?
Old 07-25-2004, 07:54 AM
IggDawg's Avatar
IggDawg IggDawg is offline
0h n0es!
Send a message via ICQ to IggDawg Send a message via AIM to IggDawg
do you have the resistor next to the battery disconnected? the ubiquitous "resistor mod"? what you're experiencing sounds a lot like the "hunting" the tranny does when you disconnect the line pressure resistor. if it is disconnected, try reconnecting it and see if you still have the issue. Keep in mind that it is vitally important to be drinking a guinness whenever you are working with this resistor. Otherwise the magic will escape and all the power will fall out of your car.
IggDawg is cool
-IggDawg
1992 Teal SVX LS-L 160k miles
4.11:1 final drive, K&B dropsprings, ART front rotors, stainless steel brake, aluminum underdrive crank pulley, Kuhmo Ecsta Supra 712's, K&N drop-in filter. Previously owned by Alacrity024. FOR SALE
1994 SVX LSi, Barcelona Red #1659, build date 11/93, 117k miles, RIP
ECUtune stage 1, bead crush, smallcar shift kit, TB bypass, SS brake lines, silencer removed, alternator and grounding wires, Mobil1 @ 117k
Old 07-25-2004, 08:24 AM
lee lee is offline
I agree with everything you said, with one potential exception. I believe Asahi, Kirin, Sapporo and/or Suntory should be substituted. Perhaps we should ask Joe for a definitive opinion of Irish Ale while working on a Japanese vehicle. I know from personal experience that Newcastle Brown helps me when I work on my Norton...as always, YMMV
Old 07-25-2004, 01:27 PM
Gargoyle's Avatar
Gargoyle Gargoyle is offline
The Croupier
I find this topic verry interseting.
I have allwase prefered a Stick but but have had several 4 speed Auto's (85- 5.0 LX Mustang) ( 87 Z-28 ) (92 Park Ave Ultra * factory super charger super fun in a straight line ) & I still have the 88 LeSabre .
Now on every one of those I found that with anything other than freeway driving I would get MUCH better response driving In 3 or D ( as opposed to O-D ) As those big monsters seemed to lug in OD & performance suffered .. Plus the LeSabre felt like it was in pain in OD @ city speeds. So I have allwase told friends & Family to get into the habit of stayin out of O-D unless on the freeway.
That said however My SVX seems to not care if it's in 3 or O-D it will smoothly drop to 3rd with a small squirt of pedal & go from 4'th to 2'nd Like a Bat outa Hadies if I drop the hammer. Now I would still love to have a 5 speed but the Auto in my SVX ( so far ) is the most responsive driver sensitive Auto I have ever driven & the shifts are super smooth with normal driving & verry firm with Aggresive driving ( perhaps is the fact I only have 56 K & I am fanatical about fluid changes )
At any rate I would love to hear more input from pep's about there thoughts on this topic..
Gargoyle,, AkA-- Allen
92 SVX LS-L 80,^^^
90 Mazda B 2200 (the dog & boat towmobile) 226,^^^
03 Yamaha V-star custom /classic 3k
Old 07-25-2004, 07:47 PM
nsm484's Avatar
Teh Geek
Thats the weird thing... its pluged in
Old 07-25-2004, 10:29 PM
NomadTW's Avatar
NomadTW NomadTW is offline
abrasive personality
Send a message via AIM to NomadTW
that is exactily what happens w/ the resistor removed or if it went bad
go to your fav subaru dealership and ask them to test the resistance on the resistor and tell you if it's right
or someone here could tell you the proper resistance that it should have
if it's bad replace it (dont' buy it from soa tho, it's surely priced obscenely, go to a junkyard or soemthing)
SV What?
Old 07-26-2004, 03:36 AM
nsm484's Avatar
Teh Geek
no SVX'es in a junkyard within a 60 mile radius.
I THINK a Tampa junkyard mite have one... but damn
thats a drive for a part ;(
Old 07-26-2004, 10:30 PM
Start saving your money.
Start being nice to your tranny.
Keep a close eye on your T fluid.
Wash your undercarriage (when it's cold) and check for burning smells when/after driving.
If it seems like pressure is low, get it flushed, find out for sure.
Install a cooler soon as possible.
