Old 07-16-2004, 07:20 PM
Guard-TL-'s Avatar
Guard-TL- Guard-TL- is offline
Send a message via AIM to Guard-TL-
Bad bearing...or something else?
So I had this prob. since day one, and now that it's almost time to fix it I want to make sure it's the right thing.
Around when I hit 58+ mph a pulsating vibration comes from the rear right wheel. Now before you say "Yes.......it's a bearing", if I let go of gas pedal it goes away and if I tap it or even worse step on it, it comes back in force. The vibration continues until I hit 80+ then it mysteriously goes away -_-
Edit: Also a clicking sound when making U turn or steering in any direction at full tilt. Kind of like a bad axle on a FF but from the rear.
help me.
-TL
Your telling me that my bottle of soda has more displacement then your honda O_O
-1992 Pearl White Subaru SVX
-1995 Briliant Black Mazda Precidia (sold :'( )
-1996 GMC Sonoma ZQ8 pickup
http://www.subaru-svx.net/photos/fil...-TL-/20502.jpg
-Taras
Old 07-16-2004, 07:37 PM
SEA Sleeper
Question
Mine also vibrates from the rear right wheel. However, I notice this at all speeds. I have taken a look at my rear differential and it has a slow leak so I initially suspected that. But you say your SVX is FF? that makes me interested in what this could be because you don't have the rear axle.
I have no idea.... perhaps an allignment would help.?.
Old 07-16-2004, 07:39 PM
Guard-TL-'s Avatar
Ah no, my is AWD. What I meant is "if" you would be driving any FF with bad boot/ axle thats same clicking I get from rear on tight slow turns.
Well almost the same, more grinding to it then clicking.....
-Taras
Old 07-17-2004, 03:26 AM
Beldin
Have you gotten under it and looked at the boots? If it is them more than likely the boots will be broken open.
Old 07-17-2004, 07:47 AM
Guard-TL-'s Avatar
Yeah I checked, they look good to me. Oh well, I’ll just have the mechanic figure this one out.
-Taras
Old 07-17-2004, 09:22 PM
Beldin
I would doubt it is a cv axle then. It may be as I had one break before the boot did but almost always the boot breaks first.
Old 07-17-2004, 11:08 PM
Guard-TL-'s Avatar
i c
-Taras
Old 07-18-2004, 07:35 AM
thumper_svx's Avatar
thumper_svx thumper_svx is offline
Either committed, or should be
Send a message via ICQ to thumper_svx Send a message via Yahoo to thumper_svx
Hmm... a thought. Have you checked the fluid level in your rear diff? If it's dry and binding that could easily cause the problems you describe.
