Old 07-01-2004, 12:20 PM
BigBlueSVX's Avatar
BigBlueSVX BigBlueSVX is offline
Donate to the mod fund
Send a message via AIM to BigBlueSVX
What's that hose?
I was cleaning up the engine the other day when I realized a hose protuding from the passenger side firewall. It appears to be leaking water onto my primary cat, which is already rusted on the edges where the water has been dripping on it. So what is the purpose of the hose? I need to move it somehow so it won't leak on my exhaust any more.
1994 blue FWD Subaru SVX L with 86k and the original tranny *SOLD*
My Cardomain page
Now part of the DSM crowd: 1990 Mitsubishi Eclipse GSX
Old 07-01-2004, 12:32 PM
SVXer95 SVXer95 is offline
Word to Yo Motha
There should be two hoses in that area. They are coolant hoses running to and from the heater core.
Collin
1995 L AWD
Locker
1987 Porsche 944 turbo
Old 07-01-2004, 01:00 PM
A/C drain hose?
Old 07-01-2004, 01:30 PM
dcarrb dcarrb is offline
Originally posted by Earthworm
A/C drain hose?
I'm sure. And it shouldn't be removed.
dcb
Old 07-02-2004, 12:21 AM
Sonar's Avatar
Sonar Sonar is offline
Yeah ACC drain.
When the ACC is cooling down the air, it also "dry's" it, and the water is collected and drained.
But you CAN re-route it
/Sonny
Internal name: "SuperSonic"
-92 ebony black with 170k KM
*** -Stress is when you wake up screaming & you realize you haven't fallen asleep yet. ***
Old 07-02-2004, 06:31 AM
Yes, but if your air conditioner has run long enough to collect condensation, your cat's hot enough to prevent corrosion from the distilled water dripping from above.
dcb
Old 07-02-2004, 01:39 PM
BigBlueSVX's Avatar
then why has it already rusted part of my primary cat?
My Cardomain page
Old 07-02-2004, 02:10 PM
If you've never driven your car in the rain, nor on a salted road, then I might agree that the A/C condensation is the culprit. Really, it's a negligilbe amount of water, compared with a single short drive on a wet road. But as Sonny pointed-out, you can always re-route the flow from the drain if you think it'll make a difference.
dcb
Old 07-02-2004, 02:45 PM
BigBlueSVX's Avatar
I understand what you are saying, and I would agree with you more except for the fact that when I was cleaning the engine, I could visibly see water dripping on the cat. And the cat isn't rusted at all where that water hasn't hit it; I can definitely see where the water has dripped down on the cat and rusted it. So I will be rerouting it.
My Cardomain page
