Old 07-01-2004, 11:46 AM
mysvxrocks's Avatar
mysvxrocks mysvxrocks is offline
Im REALLY addicted! CANT STOP!
Send a message via MSN to mysvxrocks Send a message via Yahoo to mysvxrocks
Valve Cover Gaskets
Does anyone know how to get to the valve cover gaskets? They are leaking in my car and I need to get them replaced. But I dont know how to get to them. Do you need to drain any fluids first and what do you need to take off? Any help would be great. Thanks ~Dennis
Old 07-01-2004, 04:49 PM
Mr. Pockets's Avatar
Moderator
1. Yes, you need to drain the oil.
2. Remove anything that's in the way.
In all honesty, I haven't removed the valve cover gaskets (I figure when I want to make my engine stop leaking oil, I'll pull the whole damned thing and replace every seal on it). But if you need to ask those questions (no offense intended by saying that) then I recommend you get some sort of manual - even a Chilton's book will help.
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 07-01-2004, 05:15 PM
immortal_suby's Avatar
Thread Killah
No - you don't need to drain the oil - it will not leak out, it will all be in the oil pan.
You can remove the battery and airbox for easier access.
The passenger side cover comes off pretty easy. The drivers side is a little tricky.
Locker Link
2015 BRZ Limited 6MT
