Old 06-30-2004, 08:02 PM
dragon8504 dragon8504 is offline
Send a message via AIM to dragon8504
thunking noise when going into reverse
just like the title says. i hear a thunking noise all most everytime that i shift into reverse. from both park and neutral. please let me know what you guys think.
Old 06-30-2004, 10:02 PM
shoden's Avatar
shoden shoden is offline
Check the bushings that support the rear differential. There are two of them located between the diff and the muffler. Both of mine were torn to pieces and I could move the diff around easily. If I was at home I'd post pictures, but I'm at work so pics will have to wait.
I had thought it was the transmission support that was damaged, and as it was being replaced, I noticed those bushings were bad too. Replacing the the tranny support solved some of the clunking, but it was in much better shape than the rear bushings, and a few days later when those came in and got replaced the clunking was eliminated completely.
Shane
92 SVX - Sold
98 BMW M3 Sedan
89 Honda CRX Si w/B16 swap
91 Honda CRX Si
Old 06-30-2004, 11:03 PM
Guard-TL-'s Avatar
Guard-TL- Guard-TL- is offline
Send a message via AIM to Guard-TL-
Pictures would be greatly appreciated.
I get that clunk when going from reverse in to drive.
Your telling me that my bottle of soda has more displacement then your honda O_O
-1992 Pearl White Subaru SVX
-1995 Briliant Black Mazda Precidia (sold :'( )
-1996 GMC Sonoma ZQ8 pickup
http://www.subaru-svx.net/photos/fil...-TL-/20502.jpg
-Taras
Old 07-01-2004, 11:29 AM
reverse thunk
For shock going from N to R, the ATSG troubleshooting chart suggests the following in order of most likely culprit;
Valve sticking
Faulty 4A accumulator
Deterioration of ATF.
I think the first two are located in the pan and would not require pulling the tranny to have your transmission specialist cure the problem.
[As above, bad support bushes does also create this problem]
Old 07-01-2004, 11:34 AM
forward thunk...
Again, the troubleshooting chart suggests the following in order of most likely....
Faulty N-D accumulator
Valve sticking
Faulty TCU
Again, the two middle ones are in the cassette in the oil pan, and more easily fixable by somone who knows what they are doing.
Old 07-01-2004, 11:57 AM
SVXer95 SVXer95 is offline
Word to Yo Motha
Might not be tranny
Even though it is probably transmission-related, make sure you check out your cv axles. A faulty outer joint would cause a similar clunking noise to the one you are describing.
Collin
1995 L AWD
Locker
1987 Porsche 944 turbo
Old 07-01-2004, 03:28 PM
shoden's Avatar
Here's a picture of the bushings, as promised:
Shane
92 SVX - Sold
98 BMW M3 Sedan
91 Honda CRX Si
Old 07-01-2004, 03:55 PM
Word to Yo Motha
Could also be motor/trans mounts.
Collin
1995 L AWD
Locker
Old 07-01-2004, 10:59 PM
JDW-SVX's Avatar
JDW-SVX JDW-SVX is offline
it's ruby red - not burgundy!!
Do you happen to have the part numbers for those Differential Bushings?
I was under the impression that those bushings were an integral part of the differential mounting subframe, and therefore not replaceable.
Jason.
1992 Charcoal Grey SVX - 165,000km
1992 Ruby Red SVX - 165,000km
....now with sequential VIN numbers!
1986 Holden (Isuzu) Piazza Turbo - 225,000km
1993 Mercedes W140 S500 Coupe - 153,000km
1990 Mercedes W124 300D - 313,000km
EG33 + 4EAT + VTD AWD = SVX
Old 07-02-2004, 08:55 AM
They aren't listed as a replacement part on 92's but seem to be on 94's
