Old 06-25-2004, 12:05 PM
Amazonparrot's Avatar
Amazonparrot Amazonparrot is offline
Now with Colder Air!
Send a message via AIM to Amazonparrot Send a message via MSN to Amazonparrot
Torque converter blowing through seals
I have recently had my torque converter rebuilit by a shop, and now that they have it back, and the TC back in the car, it keeps blowing seals everytime they drive it. Runs beautifully, blows a seal. They have now used both the OEM subaru seal, and an aftermarket seal. My car has been in the shop since march, and now i am getting very irritated....could someone suggest what might be causing this. Any help IS VERY APRRECIATED
1992 Subaru SVX LS-L Ebony Mica: Custom Cold Air Intake, Smallcar Shift Kit, ECUtune Stage 1v4, Flowmaster Exhaust, UR underdrive pulley, 4.11 gears, iRotors Drilled and Slotted rotors, Axxis Brake Pads, 18" Enkei Wheels w/Pirelli Pzero Nero M+S, 20% Window Tinting, K&N Panel Filter, Rockford Fosgate Sound System w/XM Radio, Removed Intake Resonator *SOLD*
2003 Subaru WRX: 2003 Impreza WRX (Aspen White); Vishnu Stage II; IHI VF-34 Turbo; Walbro fuel pump, STi Injectors, Vishnu Up-pipe, Down-pipe and Signature 3" Cat-back; Samco Intercooler hoses; JIC Coilovers; STi A-arms; Whiteline swarbar bushings; Stoptech 13" rotors w/4-piston calipers; Braided Steel brake lines; 17" Rota Wheels with 225/45/17 Falken Azenis (R-Comp).
Charlottesville, VA Represent! (voted #1 place in America to live!)
http://www.subaru-svx.net/photos/user.php?Amazonparrot
Old 06-25-2004, 12:16 PM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
Sorry to hear that Andrew... I'm not sure, but I'd have them check the line pressure in the tranny to make sure it's at factory spec.
A friend of mine in town blew through 3 Level 10 trannies in his modified '00 SVT Lightning, and when they checked the line pressure, it was 2.5 times higher than spec!
-Chike
2006 Steel Gray WRX TR (sold)
Old 06-25-2004, 02:18 PM
red95svx
-Chike
Yeah, that's my thought. Don't go back to these guys!
Old 06-25-2004, 02:36 PM
lee lee is offline
an outside guess might be that they are failing to fill the torque converter with ATF before installing. I have heard of seal failure when this is not done, but don't know first hand if true or how likely.
