How do I remove a front corner light
Need to replace my broken d. side front corner light and am at a loss on how to remove and replace it. Anyone know?
British vehicles are my last ditch attempt to keep the nasty Italian thoughts in my mind at bay. So far its working. |
Well, going from memory...
If you look at the corner light, there should be a small (3" long)bracket coming off of it and screwing into the frame behind the headlights. Unscrew this bracket. On the back side of the corner light, there is a metal prong with a tip that is slightly wider than the rest of the prong. It slides through a rubber grommet and holds the lamp in place. To remove the lamp, you have to pull directly forward on it until this prong slides out of the grommet. It's pretty easy if you pull almost straight forward while wiggling the lamp around. But, the one screw is the only thing you have to remove (and the bracket that the screw goes through is useful for pulling on to get the lamp out). Then unclip the light bulb connector and you're free.
Time for my very own long list of mods: 92 SVX LS-L - Ebony Pearl - 2002 WRX 5MT trans w/STi gearset (rebuilt & installed myself ) - BMW E46 HID retrofit - Kenwood Headunit - Phoenix Gold 75x4 RMS amp - Alpine Type R 6.5" front components - Alpine Type R 6x9 3way rear speakers - 18"x9" Rota G-Force wheels w/225/40ZR18 Toyo T1R's - Mychailo's custom springs - Urethane front & rear sway bar bushings - KC exhaust (2.5" dual magnaflow) - Escaine seat swap - Removed Spoiler I don't care if Subaru says it's STI...it will always be STi to me |
Thanks,
I looked at it and saw the braket you speak of. Figured that couldn't be it and that I was gonna need to remove the whole fender or under cover. This should be fairly easy.
Yes, that is the way that it comes apart. Just take your time and don't force anything and you should be fine. One of the easiest lights to take off.
Thanks guys, took all of 5 minutes. It just didn't seem likely that there would be just 1 screw holding it in. She's all prettied back up from her little garage incident.
