Old 11-14-2003, 08:29 AM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Question Camber kits
Anyone know about the camber kits being offered on eBay?
http://cgi.ebay.com/ebaymotors/ws/eB...ADME:B:SS:MT:1
I'm wondering if they're designed specifically for the SVX or just a hack mod from existing kits.
Thanks in advance for everyone's feedback.
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 11-14-2003, 08:35 AM
http://www.subaru-svx.net/forum/show...ht=camber+kits
here ya go
Old 11-14-2003, 09:36 AM
mbtoloczko's Avatar
sans SVX
here ya go
My comments in that post weren't in reference to the kit that SVXRide is looking at on ebay at this time.
With my front springs in your car, you probably will not need a camber kit with the front, but it will be right at the limit. The range with the stock front camber bolts and my springs is about -1.4 deg to -0.8 deg. -0.8 is an ok number. The stock nominal spec is -0.4 deg. Our cars don't need to dial in a huge amount of camber in the front because our cars have a large amount of caster (much more than most cars) which automatically builds in camber as the steering wheel is turned. You'll want to put some camber bolts in the rear though. The ones I have in my car are this brand:
http://www.specprod.com/
The part# is 81260
You can get them at many alignment shops for about $25-$30. I've had no problems with mine. Simple to install and easy to use.
Mychailo
Visit my locker
Old 11-14-2003, 09:47 AM
SVXRide's Avatar
The part# is 81260
Mychailo,
thanks...so your suggested "rat tail file" mod will cover me for the front end?
-Bill
Old 11-14-2003, 09:56 AM
mbtoloczko's Avatar
sans SVX
Originally posted by SVXRide
Mychailo,
-Bill
That mod is to pull back the caster closer to spec. I recommend it as you loose a fair amount of caster when the front is lowered relative to the rear.
Mychailo
Visit my locker
Old 11-14-2003, 10:37 AM
SVXRide's Avatar
Mychailo,
thanks!
-Bill (noting that he needs to brush up on his "alignment speak")
Old 11-14-2003, 02:39 PM
JLittell
Thumbs up
Mychailo, I have to say that you're pretty knowledgeable when it comes to the SVX moreorless in the suspension dept! Thanks for all your input and helpful advice!!..Oh yeah, Porter is good one to refer too!
Old 11-14-2003, 05:40 PM
Porter
With my suspension setup I am running about 1.5 degrees negative camber in the front, and about 1.2 degrees negative in the rear. 0 toe front and rear, ride height roughly stock. Maybe slightly higher than stock in the rear.
It is extremely neutral (slight understeer) on corner entry and mid-corner, and I can put the tail out slightly on corner exit under power.
Old 11-14-2003, 10:17 PM
SVXRide's Avatar
Porter,
How long (miles) have you been running with this set up? How are the tires wearing?
Thanks.
-Bill
Old 11-14-2003, 10:41 PM
Motorsport-SVX's Avatar
Motorsport-SVX Motorsport-SVX is offline
check out www.planetsvx.com
that particular Ebay kit wont work or
fit the SVX, and one day they will find out if someone actually buys a set and ends up returning them.
The best and only kits I know of are as easy as replacing
one of the lower strut bolts with a camber offset bolt.
Done correctly with no grinding, cutting etc....
http://store.yahoo.com/svx-motorspor...ncambolki.html
My mom will forever live in me and
never be forgotten, one day Ill see her again
CLICK the LINK below to Visit the SVX Store:
http://www.planetsvx.com
http://www.motorsportwarehouse.com/svx/sig2.jpg
Cars in the garage:
92 Toyota Soarer Single Turbo JDM RHD
70 Boss 302 Mustang 39k original miles
97 SVX Lsi
92 Liquid Silver Murano-ized (1st of its kind)
71 Cougar Xr7 Conv 351c 4v 4spd
69 SS Camaro 350
71 Nissan RHD Fairlady Z
70 Stang Fastback
70 Amc AMX 390
71 240z
89 Conquest TSi w/ 5.0 v8 swap
84 Mustang GT Turbo conv
"good, if it bleeds, we can kill it ....."
Old 11-15-2003, 09:01 AM
Porter
Porter,
Thanks.
-Bill
I've been running this way about 15,000 miles. The tires are about done but they have 35,000 miles on them now. Hooray for RE950s. Tire wear has been even, edge to edge. I still cup the outer edges a little when I do too much sliding in the mountains though...
