Old 08-27-2003, 09:53 PM
alacrity024
idiot lights..
what do the following idiot lights indicate when they all come on simultaniously when i turn the wheel: steering, battery, stop light, brake?
-adam
Old 08-27-2003, 10:52 PM
Seraph's Avatar
Seraph Seraph is offline
I abuse them one at a time
Save some money for a new alternator
Lwin M. Maung (Member # 147)
Current SVX: NONE
Old 08-28-2003, 03:07 PM
alacrity024
well.. do you think that the fact that i'm running an underdrive pulley could have an impact on that?
i'm told that if you run an underdrive pulley, it's a good idea to do the "alternator wiring mod" which i haven't yet done..
i recently pulled my alternator out and had it bench-tested (i thought it was the culprit for a different problem) and it performed flawlessly, so i'm not positive that it's an actual problem with the alternator itself, i think it might just be that it's not getting QUITE enough "spin" from the crankshaft..
any thoughts?
-adam
Old 10-11-2003, 07:23 PM
The last time my alternator had problems I couldn't reproduce the problem to show what was wrong. It seemed to just act up whenever it wanted to. I had it bench tested and it was fine. They changed the voltage regulator anyway and it's been fine ever since.
Old 10-12-2003, 05:14 AM
92black svx
i agree whith the other guys my alternator tested good and i changed it from what i read on the form and all the lights went away so id have to say its ur alternator as well
Old 10-12-2003, 08:07 AM
Subafreak's Avatar
Superbeast
Maybe it has to do with THE TRANNY ONLY HAVIN 2 SPEEDS!!! I think the alt. is the least of your problems. But uh, yeah it's probly your alt.
