Old 06-01-2003, 06:43 PM
6evil9
Sun roof sticking
Hey everyone,
i got my sunroof problem, it needs a push when i try to open it
i ve read the thread bout it, and lubricated with that silicon lubricant thingy, but well its better but still need to push it up
i lubricated that weather strip round the sunroof, and some otha parts but still its sticking, considering the high kms of my 92 SVX... i can suggest the motor needs oil too...so any ideas how to disassemble the sun roof and lubricate the motor or there s some other reason with sticking sunroof...????
thx
Old 06-01-2003, 06:55 PM
I had to clean the track and other parts before it would run properly. The lubricant had become thick and gummy with age and had lots of dirt in it. Once I cleaned everthing and then put the silicone back on, it worked much better. Another thing that some have tried is to tighten the clutch. That might make it work better too, or you will just have to push up on it when you want to open it.
Old 06-01-2003, 08:57 PM
Uncamitzi's Avatar
Member #447
Sticky
I find that when I'm at speed (55 +) it opens fine... It needs a push below that... (and I've cleaned the tracks and the motor.)
Mitch Hansen
"uncamitzi"
This is a Dark Ride
Old 06-01-2003, 09:49 PM
I would suggest then that you only open your sun roof at 55+! Mine needs a little boost once in a while too. I will have to test it at speed +.
Old 06-02-2003, 10:05 PM
6evil9
so how do i tight the clutch or lubricate motor??
hey man, so how can tight the clutch or access to da motor?
should i disassemble whole roof? or how to do it?
so far i found only 2 screwes and still in process of figuring out how this sun roof thingy works
hmm 55+ if u talk bout miles, then we got limit of 60 on da motorways and round 30 on roads...which does not sound promising to me.,...
which does not sound promising to me at all lols
Old 06-02-2003, 11:44 PM
Uncamitzi's Avatar
Member #447
Re: so how do i tight the clutch or lubricate motor??
Yep... 55 mph or so... at 120 mph it just flies open
Mitch Hansen
"uncamitzi"
This is a Dark Ride
Old 06-02-2003, 11:51 PM
What about in reverse?
Old 06-03-2003, 03:33 AM
6evil9
Red face but if serious, HELP
but if to be serious, what else can i do...just aint cool to push the roof up with my thumb when i press the button to open roof, lols aint stily
Old 06-03-2003, 05:37 AM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
Try pulsing the button twice and on the 3rd button press you hold it. Seems to work for me if it sticks.
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 06-03-2003, 12:05 PM
Uncamitzi's Avatar
Member #447
mmmmmmm.
full speed in reverse...... (to be read as Homer Simpson)
Mitch Hansen
"uncamitzi"
This is a Dark Ride
Old 06-04-2003, 07:59 AM
fab9joe
i also have this problem and have learnt to deal with it. a mild push gets it going, it is like the motor is too weak.
Old 06-04-2003, 02:01 PM
gschabel
Yes, I would like to know how to tighten the clutch also.
Mine was working fine all winter, but when the weather got warmer, it now always sticks.
I noticed that the spring activated locking system (when closed) might double to push the end of the roof open during the opening mode, as part of the mechanism pivots and seems to be high enough to force the roof upward. Perhaps these springs get weak over time, plus with some grit in the track that is hard to get to, could contribute to the sticky openings, or less forceful pushing up of the mechanism.???
My 2 cents!!!!!
Old 06-05-2003, 07:10 PM
That seems to happen with age now doesn't it?
The clutch nut is hiding under the round plastic cover behind the interior light. I haven't adjusted mine yet but from what I've heard it doesn't need to be adjusted much.
