Tire / AWD Question
During a routine oil change, my mechanic noticed that my front tires were worn down to the cords on the inside portion of each tire. The rest of the tread across the tire appears fine. The fronts must have too much negative camber. The tires in the rear are fine. All 4 tires are stock size and made by Ventus. If I cannot find Ventus tires then I'm stuck buying 4 new tires...right? It occurred to me that mixing fronts and rears of the same size but different manufacturers is a no-no in AWD. Is that right?
You're looking for tires that start out the same size and wear at the same rate. Tires from the same manufacturer are more likely to have those characteristics than tires from different manufacturers.
I don't know the consequences of having a slight difference front to rear, but someone here probably does. Good luck!
Dick ************** 1999 Legacy GT 30th Anniversary Edition 2001 Outback Sport |
I think that you are SOL. The spec is for all tires to be no more than 1/4" different in circumference. Unless your tires are almost brand new, you will either have to get 4 new tires and have your wheels aligned, or look into getting 2 new tires shaved down.
Mattski 97 LSi Ebony Pearl 130k Midlife Crisis 93 Legacy Wagon 180k Training Wheels 98 Outback 180k 98 Dodge Durango 120k Ski Bus A multitude of skis to feed my need to go faster, faster until the thrill of speed overcomes the fear of death. |
Yes, that is right. It is very important to have the same tread, and the same size tire. Even amounts of wear (new vs almost worn out) can be a problem. They should be the same tire with the same amount of wear. Maybe someone else will shed some light on this topic.
i think its like all the wheels have to move at the same time and rate
Re: Tire / AWD Question
I think they are made by Hankook.
Mike 92 LSL Teal 103k 00 RS 2.5 Silverthorn Metallic 36k 68 Chevy Camaro 07 Forester XT Sport |
Re: Re: Tire / AWD Question
Mike |
This might be a good time to point out how crucial it is to rotate the tires regularly on the SVX. Even wear = longer life for your running gear and your tires.
Original set of RE95's went 70K. Current set of RE910's are near that, and appear to have quite a bit of life left. No tranny problems either.
Steve '95 Polo Green SVX L AWD, 188K - "Kermit" (Gone, but not forgotten) '02 Outback LLBean, 56K '02 Black Sapphire Volvo V40, 133K - "Shadowfax" '06 Triumph Tiger, 19K '99 Suzuki DR350SE, 8.5K - "Geezer Killer" <*}}}}>< ~ ~ ~ ~ ~ ~ ~ ><{{{{*> |
Thanks for all the responses. Yes, Ventus are made by Hankook. The risk there is by purchasing just two they may be slightly different (new version let's say). Mattski had it right. 4 new tires and a front end alignment. Yokohama Avid V4's from the Tire Rack all around are arriving today.
When you look at the tire wear on the front it is quite alarming looking at the wear. The fronts must have severe negative camber to wear that bad plus the steering has become quite darty which would make sense. Anybody else have excessive inner tire wear problems? |
