Old 02-06-2003, 06:32 PM
svx_commuter's Avatar
Stop Lamp Warning Light
The stop lamp warning light has been coming on sometimes when the brake is applied. I checked the bulbs and the bulbs are fine, at the time the warning light was not on. ???
Old 02-07-2003, 05:49 AM
Re: Stop Lamp Warning Light
This was happening to me also. The fault on mine was fluid level in the reservoir. It looked OK on the outside. However, there is a float switch on the inside, this was sticking a bit, just low enough to turn on the light. Did it mostly in the morning till the brake fluid heated up, and presumably expanded a bit.
BTW commuter, if this is the problem, check your flexible brake pipes. One of mine had a weeping leak which caused the low level.
Old 02-07-2003, 06:13 AM
Joe this is the other "brake lamp" light not the "brake" light. I never saw this one before it came on. It comes on when a stop bulb burns out.
Old 02-07-2003, 06:30 AM
mohrds's Avatar
mohrds mohrds is offline
Fight Eminent Domain Abuse!
Send a message via AIM to mohrds Send a message via Yahoo to mohrds
Just replace the bulbs. If the light is coming on, one of the bulbs are on the way out. It may be working intermittently. Its a small cost to replace all four bulbs.
Doug
1992 LS Touring (6/91) - Currently undergoing a five speed swap
Black over Claret with spoiler; 235,000 miles; Mods: 2002 Legacy 5 speed, ACT Pressure Plate, Excedy Clutch, Short Throw Shifter, Aussie Powerchip
Black over Claret with 2.5" setback spoiler; 202,000 miles; Mods: B&M Cooler
1994 LSi (4/93)
Bordeaux Pearl; 198,000 miles; Mods: Weight reduction.
1969 Mustang GT Convertible
1970 Mustang Convertible
2000 Ford Excursion
Sola lingua bona est lingua mortua.
Old 02-08-2003, 11:39 AM
Supposedly the "stop Lamp" comes on when you burn out 1 bulb and stays lit. However, if you burn out a second bulb, tha "Stop Lamp" goes out.
Another common problem is the stop lamp checker relay. This is located in theright side in the trunk, behind the panel, in front of the washer fluid reservoir. The design is such that if moisture gets into this area the checker relay acts as a reservoir to collect and hold water. This was my problem.
Check the bulbs first. The relay is a simple 1 plug/1 screw operation. Cost of the part is about $38.00.
Old 02-09-2003, 09:44 PM
gcookaustin
Next time that happens, pull over and have someone step on the pedal, or place something on top of it (a heavy book?) and see which bulb is going out. Had some problem; sometimes the light would come on so I replaced that bulb and it's been fine.
Old 02-09-2003, 11:05 PM
Seraph's Avatar
Seraph Seraph is offline
I abuse them one at a time
I can do a perm. fix for you. Send me your current lights at the back with 500 bucks. I will put LEDs in them. Not the cheap 15 bucks with 5 LEDs either.
L
Lwin M. Maung (Member # 147)
Current SVX: • NONE
Other current cars:•2001 Jeep Grand Cherokee Black
Old 02-09-2003, 11:17 PM
kuoh kuoh is offline
$500?! That stop lamp better be bright enough to guide ships into the harbor on a foggy night! ;-)
KuoH
Old 02-10-2003, 02:35 PM
oab_au oab_au is offline
stop light bulbs.
The stop light warning system measures the amount of current that flows to the stop light bulbs. As the bulbs age the filament erodes away, this raises the resistance so less current flows. Try renewing the bulbs.
One Arm Bloke.
Tell it like it is!
Old 02-10-2003, 03:34 PM
Seraph's Avatar
KuoH
I guess you have not seen the LED taillights on the SVXes yet. At least the 2 prototype LEDS taillight SVXes...
These things are bright enought to light up a cityblock. And I kid you not.
L
Current SVX: • NONE
