Go Back   The Subaru SVX World Network > SVX Main Forums > Product and Service Reviews > Interior Car Care Products
Old 03-16-2013, 11:31 AM
nimrod8560 nimrod8560 is offline
KeylessRide replacement remote
Had my factory keyless entry remote stop working in my 92 the other week even after replacing the battery. So after searching the forums for a factory replacement I found keylessride.com. They currently have 2 replacement choices for our SVX: a similar square FOB w/2 buttons and a round FOB w/2 buttons. I choose the round remote and the total for me was $45 shipped. Its similar in weight and a slightly thinner profile. It comes with programming directions specifically for the SVX, has a red indicator light, and both buttons do the same function after programming them to the SVX. Pic below shows the size reference.
So far it functions the same as the old remote. No added range unfortunately. Worth purchase in my opinion.
Old 03-16-2013, 11:34 AM
Re: KeylessRide replacement remote
I have several of the rectangular ones and they work great. If you want extra range, point the fob at your chin and it will add range. Try it, it works.
Old 03-16-2013, 11:48 AM
Doesn't that only work if you have a steel plate in your head or shrapnel?
Old 03-16-2013, 05:18 PM
It isn't required, but it helps.
Old 07-12-2013, 12:20 PM
trueblue's Avatar
trueblue trueblue is offline
Send a message via AIM to trueblue
Red face Re: KeylessRide replacement remote
Does anyone have programing instruction for the keylessride remote? I can not find my instructions to reprogram it after a long shutdown.
[SIGPIC][/SIGPIC]Kenyatta
The farther backward you can look, the farther forward you are likely to see. -Winston Churchill
My baby: 94 lsi
My fast baby: 2001 Suzuki Marauder
My new baby: 2010 Subaru Outback
Old 07-12-2013, 01:19 PM
Originally Posted by trueblue View Post
Does anyone have programming instructions for the keylessride remote? I can not find my instructions to reprogram it after a long shutdown.
Programing instructions in the How-to documents HERE
They are the same for the OEM and keylessride remotes.
Old 07-18-2013, 04:52 PM
trueblue's Avatar
Got it. Thanks for the info, now it seems my security system is stuck on on and will not go off when the switch is pushed. When/if I get that problem solved I will have what I need to program the remote.
Thanks again
Kenyatta
My baby: 94 lsi
Old 07-18-2013, 05:58 PM
Usually a steady ON red LED is a sign of a security module which has died.
Old 09-06-2013, 07:08 PM
jcimos's Avatar
jcimos jcimos is offline
I know i should not be piggy backing off some else thread, but I don't have a remote for my 92. Is there anyway for getting a FOB that works and can be programmed?
ALL WAYS JUDO CHOPIN'
"Wait...your grill...is that chicken wire?"
Old 09-06-2013, 07:37 PM
Originally Posted by jcimos View Post
I know I should not be piggy backing off some else's thread, but I don't have a remote for my 92. Is there anyway for getting a FOB that works and can be programmed?
If you have the original security system installed and a red light on the dash that works, you can just order a keylessride remote and follow the programming instructions.
You don't need to have the original remote.
