Impreza 4 Piston Caliper Swap?
anyone knows if there is any Subaru OEM piston calipers that would fit our cars?
Re: Impreza 4 Piston Caliper Swap?
the STi brembos will bolt up but they wont work... Other than that, no....
will bolt but not work? more details? thanks!
1. Click on Search.
2. Enter the keywords for your query. 3. Review the results. http://www.subaru-svx.net/forum/show...ghlight=Brembo __________________ |
They'll bolt up, but the bolt locations on the SVX are further from the hub than on the STi, so the calipers will be mounted further out. The max rotor size the 4-pot Brembos are designed to work with is the one on the STi. On the SVX you would need a larger rotor, the end result of which would be either the caliper grinding into the rotor, or the pads hanging off the end of the rotor.
I've got Movit (from Germany) 4 piston calipers on my SVX, I can stop real quick...I just worry about cars behind me trying to stop. Great brakes but pricey, just replaced the front rotors and pads...over $1600.00!! Not sure what I'm going to when I have to replace them next time.
1996 Black, 134,000 KM, with Custom Stainless from Headers to Stebro, 17" Wheels, Michelin Pilot Sport PS2 225/45/17 Cold Air Intake. Pioneer AVIC D3 GPS/Video/Sound/Sirius/Bluetooth/USB Koni struts/ground control coilovers Stainless steel brake lines K&N filter, custom front grill H.I.D low beams 5000k 35w, H.I.D fog/driving 4500k 35w Clear front and corner lens |
