Old 03-28-2009, 12:30 PM
kwren's Avatar
kwren kwren is offline
Any ideas why the front windshield washers?
won't squirt the stuff?
Yes, the hose is connected and there is a bunch of stuff in "the tank"
Any ideas appreciated!
Keith
Old 03-28-2009, 12:56 PM
dcarrb dcarrb is offline
Re: Any ideas why the front windshield washers?
If you can hear the pump, could be trash has clogged the nozzles (clear with a straight pin). No sound = bad switch, bad connection, bad pump.
dcb
Old 03-28-2009, 01:59 PM
kwren's Avatar
ty will check!
Keith
Old 03-28-2009, 02:19 PM
svxash's Avatar
svxash svxash is offline
Mine had build up in them and I took a small pin to them and then blew them out with the air hose and they worked great. Also when you use the pin to clean them out it might move the angle of the nozzle so you will have to readjust them after reinstalling them. Mine were shooting over the car after I installed them.
1997 Boudreaux LSi
1994 SVX LSi(SOLD)
Kool Blue air filter, 4500k HID's, airbox mod, Hella horns, WRX 6 disc stereo, Infinity Reference and Clarion Pro Audio speakers, Infinity basslink sub, ECUtune Stage 1v5, ECUtune TCU, Power mode mod, Mad muffler mod v1.3
Old 03-28-2009, 02:29 PM
When I have had that problem, I disconnected the hose from the hood nozzle and squirted them so it would flush the line. Then I unclogged the nozzle and tried again. Usually that does the trick. Good luck.
Old 03-28-2009, 02:55 PM
if it gets cold say -15 or so, they can freeze and stop as well.
1985 Brat GL 138k
91 CRX Si 40k
91 CRX Si 155k
97 SVX Lsi 70k
2003 s2000
91 RT4WD 166K
Old 03-28-2009, 02:58 PM
Hah, in my case I showed Old Tom how the windsheild washers didn't squirt when I pulled back on the level, when he saw this he reached over and pressed the correct button on the end of the stalk to make them come on. I felt pretty stupid, but happy that it was human error rather than mechanical error.
Old 03-28-2009, 03:07 PM
Teeheeheeheeheehee, snort.
Old 03-28-2009, 07:53 PM
Hondasucks's Avatar
Subaru Technician
Just a side note from a technician's perspective:
Use a good quality washer solvent with ammonia, a lot of the cheaper stuff without ammonia, especially if you just top the tank off with water, can let all sorts of funky stuff grow in the tank. I worked on a Toyota minivan that would like, shoot snot out of the squirters, it was pretty gross.
1986 VW Jetta
