Old 09-08-2008, 06:10 PM
stock camshaft specs
I am having a performance valve job done on my cylinder head and the machinist wants to know the specs of our stock camshafts. I did a little research on the network and there is A LOT of information on camshafts, in fact too much for a novice to be able to decifer what info i really need.
So that being said, what camshaft spec info will my machinist need to complete his job? I was planning on keeping the camshafts stock to avoid reliability issues and having to convert to solid buckets...now that i think about it, is it possible to obtain a more aggressive camshaft without sacrificing too much daily drivability? thanks in advance.
Old 09-09-2008, 11:15 PM
oab_au oab_au is offline
Re: stock camshaft specs
Hi the standard valve timing is measured at 0.010"
Inlet opens 2*BTDC, closes 54* ABDC. Lift is 7mm.
Exhaust opens 55* BBDC, closes 9* ATDC. Lift is 8mm.
There is a cam that has been used before, welded and ground by Delta Cams. It was a modified Inlet cam that increased the lift to 8mm, with a 247* duration. It helped the torque to continue up the revs a bit further.
One Arm Bloke.
Tell it like it is!
Old 09-23-2008, 09:30 AM
Harvey, could you please define the acroynms? (BTDC, ABDC, BBDC and ATDC). Thanks, Chris
Old 09-23-2008, 09:42 AM
RallyBob's Avatar
RallyBob RallyBob is offline
Registered fabricator
BTDC = Before Top Dead Center
ABDC = After Bottom Dead Center
BBDC = Before Bottom Dead Center
ATDC = After Top Dead Center
Bob Légère
EG33 Impreza tweaks
Old 09-23-2008, 04:52 PM
Hi Chris, Bob has the words right, but a picture saves a lot of words.
Blue is inlet duration.
Yellow is exhaust duration.
MOP. Is maximun valve opening point, or Lobe center.
One Arm Bloke.
Tell it like it is!
Old 09-23-2008, 07:11 PM
thanks guys, I'll let pass the info onto my machine shop guy tomorrow!
