Old 11-11-2006, 11:41 AM
2.5InchTrueDual's Avatar
2.5InchTrueDual 2.5InchTrueDual is offline
Will
Thumbs up Need some ABS help
So yeah, i just resently did a tranny swap, all went well until i got it all put back together. It seems to me like my brake power booster isnt working or something. The brakes are hard to apply, basiclly it feels like the booster went out. After driving over 20 mph the ABS light comes on and stays on till you shut it off, i checked the direction of vaccum flow through the booster vaccum line making sure the chech valve was facing the correct way. anywho any info will be benifical.
Old 11-11-2006, 12:17 PM
elninoalex's Avatar
elninoalex elninoalex is offline
Registered Abuser
Is it possible that you accidentally disconnected or damaged one of the ABS trigger wires?
Old 11-11-2006, 12:18 PM
gest24's Avatar
$ gest24 $ gest24 is offline
#1 6MT In Cali
Send a message via AIM to gest24
Check the vacumm hose on the booster that it isn't in backwards. There is a check valve in there and Tom and I made the same mistake during my swap.
1992 SVX LS-L: Now TomStock Stage 3... 6MT, R180 Rear, Tomstock Short Shifter and hard rubber mount, Group N Motor and Tranny Mount, Stage 2V6 Chip, Z32 MAF, Stage 3 CAI, Stebro, Intake Cams, 17" STi BBS Powder Coated Black, Bridgestone Potenza RE070, and Koni inserts w/Mychailo's Springs!
Sand Diego SCCA Solo 2 #308
RIP
84 VW Scirocco
02 WRX
88 XT6(regret the day I left her behind)
socaleuro.com They like the flat 6...
Check My New Homepage..
