Old 11-01-2006, 07:56 AM
msvx95's Avatar
msvx95 msvx95 is offline
It's just a phase
Lug Torque
Hey, since my computer bit the dust, I am not able to use my SVX CD service manual and the standard manual for the car is missing currently.
My car is on jacks right now and I am going to rotate the tires. So my question is simply what are the torque values to tighten the lugs? I saw 58-72 ft-lbs somewhere on this site and I also saw 72-86 ft-lbs. I guess the range meaning lower number for used parts, higher number for new parts.
I have a 95 svx and will be reusing the current lug nuts.
Thanks
1995 Subaru Svx L / AWD
Old 11-01-2006, 08:06 AM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
85-90 ft-lbs works...might want to take them to 45 first if you want to make sure you've got an even torque (star pattern)
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 11-01-2006, 09:26 AM
msvx95's Avatar
It's just a phase
ok, but I'm looking for the subaru spec
Old 11-01-2006, 09:38 AM
SVXRide's Avatar
and 85-90 is within the Subaru spec...(I'd have to check my shop manuals, but I believe the spec is 75-100 ft-lbs)
-Bill
Old 11-01-2006, 07:56 PM
SomethingElse's Avatar
word words wording
I always use 1,080 inch pounds
Eric
Old 11-01-2006, 10:44 PM
Bobb Bobb is offline
Torque
Hi Matt, According to the Subaru Owners Manual for the 1992 SVX on page 10-5. Wheel nuts are torqued at 72-87 ft-lbs. Happy rotating and take care, BOBB
Old 11-02-2006, 12:57 AM
Trevor's Avatar
Trevor Trevor is offline
The correct torque, is that which enables you to remove and replace a wheel, using the OEM equipment and not an impact power operated device. Not usually available in the wop wops in the middle of a raining night.
Trevor, New Zealand.
Old 11-02-2006, 04:36 AM
msvx95's Avatar
It's just a phase
Thanks everyone....I did open my manual up at home and Bobb is correct at 72-87 Ft-lbs.
I brought a torque wrench home and set it at 72, but stupid me, it was an IN-LB wrench (doh!!!) So Eric, I'd need at least 864 in-lbs....LOL
So I just cranked them down by hand until I can get the correct wrench.
I know they were over tightened...I had to get a breaker bar on the wrench to free them up....the stealership must have impact wrenched them from the last service I had.
