Old 03-13-2006, 10:16 AM
SVX10's Avatar
SVX10 SVX10 is offline
Fighting with electricity
Send a message via AIM to SVX10 Send a message via Yahoo to SVX10
Trans & bearing tool
Hey guys. I'm thinking about buying a shop press to assist me with a 5MT rebuild. Would this also be useful for bearings? Could I take out my rear hub assembly and use this press to extract the bearing from the hub? It would be cheaper to buy the press and some adapter plates specific to the SVX bearing than it would be to buy the hub tamer.
Thanks in advance.
Mat
Time for my very own long list of mods:
92 SVX LS-L - Ebony Pearl - 2002 WRX 5MT trans w/STi gearset (rebuilt & installed myself ) - BMW E46 HID retrofit - Kenwood Headunit - Phoenix Gold 75x4 RMS amp - Alpine Type R 6.5" front components - Alpine Type R 6x9 3way rear speakers - 18"x9" Rota G-Force wheels w/225/40ZR18 Toyo T1R's - Mychailo's custom springs - Urethane front & rear sway bar bushings - KC exhaust (2.5" dual magnaflow) - Escaine seat swap - Removed Spoiler
I don't care if Subaru says it's STI...it will always be STi to me
Old 03-13-2006, 10:25 AM
Speedklix's Avatar
Speedklix Speedklix is offline
Locker Link Solution
I thought about that once, never tried it though.
What role will the press play in the 5mt?
-Mike
ECUTune2v7 - 4.11 5 Speed - Sprung 6 Puck Clutch - D&S Rotors - SS Brake & Clutch Lines - HKS Panel Filter - HeaderBack Exhaust -80GB Hard Drive - GroupN Engine Mounts - - some other "tricks"
[SIGPIC][/SIGPIC]
In progess: track down mystery noise <-identified, paint the new dash, get better pic
Spring plans: Replace Trans - Integrate ECU with the carputer - Suspension - Go back to STI Filter - Paint? Maybe not - Next Oil change: Purolator L30165
Member #995 | My Locker | My New Locker
Catch you next at: ? Auto-X ?
Old 03-13-2006, 10:38 AM
AvPPoW AvPPoW is offline
Yes, this is how I did the bearing on Mike621's car
Old 03-13-2006, 05:00 PM
SVX10's Avatar
for the 5mt the press will serve as an installation tool for a strengthened gearset. I guess for 100 bux I could find plenty of uses for it. If all else fails, it'll be the coolest can crusher ever!
Old 03-13-2006, 05:01 PM
SVX10's Avatar
Did you get plates made to press out the bearing, or were you able to do it without any special tools?
Old 03-13-2006, 05:11 PM
Speedklix's Avatar
Ahh, got it.
-Mike
[SIGPIC][/SIGPIC]
