Old 12-22-2005, 03:39 AM
Kay McRae
Transmission shot - need advice
Hello all,
The auto transmission of my bf's SVX is completely busted.
He would like to replace the auto tranny with a 5 or 6-speed one. I've read through Huck's document on how to convert this.
Anyway, here in Belgium hardly anyone knows what an SVX is. (Only 5 driving around here)
One mechanic first claimed he could do it with all the necessary parts from a Subaru Impreza GT Turbo, but then later claimed it would never fit.
Can anyone give me some decent advice please?
Will the transmission of A Impreza fit? Or will the one from a Legacy be better as this is also a 3.0?
Thanks!!!
Grtz,
Kay
Old 12-22-2005, 04:43 AM
Sixpack Subaru
Talking
Impreza trans will fit, 5 OR 6 speed, just make up some shafts and mounts, add the pedal box and 'graft-in' some speed sensors etc and you're done!!!
(Done one myself,(6-spd), took me around 3 weeks including waiting for the shafts to be made/resplined. Cheers on the Cafe's there......
HTH
Cheers
Sixpack Subaru-do a search, (again?), there is more info here I am sure!!
Old 12-22-2005, 04:51 AM
SlonSVX5mt
Talking :)
Yes all impreza's and legacy's will bolt on all you need is a stronger clutch and pressure plate... stage 2 and up.
Also svx is not a 3.0 it's a 3.3 liter boxer six, maxima is a 3.0
Originally Posted by Kay McRae
Hello all,
Thanks!!!
Grtz,
Kay
Old 12-22-2005, 05:15 AM
But the new Legacy has a 3.0 Boxer 6 in it, I think that is what they where referring too...
Old 12-22-2005, 06:37 AM
Sixpack Subaru
Talking
but the trans is the same
Old 12-22-2005, 06:42 AM
Kay McRae - Welcome to the site. You should be able to get all of the information you need for this project here. It may take a little time, but it should be here. Good luck with the project.
Old 12-22-2005, 10:45 AM
Earthworm's Avatar
Meow!
Welcome to the site!
I used a 2002 WRX 5spd tranny and I did not have to touch the axles. The driveshaft does need to be lengthened though.
Old 12-22-2005, 11:21 AM
pavanbabut's Avatar
pavanbabut pavanbabut is offline
Send a message via MSN to pavanbabut Send a message via Yahoo to pavanbabut
Hello all,
Thanks!!!
Grtz,
Kay
Welcome to the site Kay. As all other members have already said, any impreza/lagacy tranny will fit into svx. I swapped my svx tranny with an 98 outbak legacy tranny. So, its not a problem with 5 spd too. There are many members over here to help you out.
-Pavan.
Old 12-22-2005, 11:49 AM
mbtoloczko's Avatar
sans SVX
All of the Subaru 5-speed transmissions will fit. The critical exterior dimensions are all the same (same length, same width at the half-shafts, same input shaft length, compatible bolt pattern on bell housing). The key differences are the gearing and the type of clutch. The later model 5-speeds have a hydraulic clutch, and gearing varies from year to year and model to model. IMHO, the US-spec WRX 5-speed has the best gearing for an SVX motor, but none of the trannys have bad gearing. The newer trannys generally have stronger gears. The hydraulic clutch system takes more work to install than the cable-operated clutch system. The SVX front half-shafts fit into all of the 5-speed trannys. The driveshaft will need to be lengthened by 2", or a late-'90's Legacy driveshaft can be used with some minor mods to the output shaft cone at the back of the tranny.
Mychailo
Visit my locker
Old 12-22-2005, 12:09 PM
Earthworm's Avatar
Meow!
^-------- What he said! --------^
Old 12-22-2005, 02:48 PM
oab_au oab_au is offline
A 97 with a dud trans.
Hi Kay, It is unusual for a 97 auto, to have terminal troubles, What happened to the auto?
You can find more on the 'European Forum', a member there is doing the same swap, in Europe.
One Arm Bloke.
Tell it like it is!
