Old 08-13-2004, 12:04 AM
svxnmx6
wrx trans and rear diff?
if i get a wrx 5 speed, do i need to change the rear diff too?? or just the trans? im bad at searching, so i figured i'd just ask. what is involved with changing the trans? im pretty good with diffs though. thanks
Old 08-13-2004, 07:58 AM
want-a-fast-svx want-a-fast-svx is offline
Send a message via AIM to want-a-fast-svx
If you get the wrx you dont need the diff due to them having the same final drive ratios. You will need your driveshaft lengthened 2in. exactly( always double check for reassurance) along with the clutch pedal assembly and a variety of other custom brackets and stuff that you will have to make...I would really suggest using the search function or atleast trying to learn b/c there is a wealth of knowlege that you need to know and thats the easiest way..
Old 08-13-2004, 11:25 AM
http://www.subaru-svx.net/forum/show...ight=5spd+swap
Old 08-13-2004, 02:54 PM
mbtoloczko's Avatar
sans SVX
Originally posted by want-a-fast-svx
.... You will need your driveshaft lengthened 2in. exactly( always double check for reassurance)...
wanta,
Did you get the driveshaft for your car lengthened exactly 2"? Just wondering because I need to do this, but I don't have time to get under the car to measure.
Mychailo
Visit my locker
Old 08-13-2004, 04:44 PM
Earthworm's Avatar
Meow!
Here's my thread for my WRX tranny install:
LINK TO THREAD
Old 08-13-2004, 07:58 PM
Originally posted by mbtoloczko
wanta,
Yes i had it lengthened exactly 2 inches, I was able to find a driveshaft from a 94 which is the two piece driveshaft.
