Old 11-15-2003, 01:23 AM
mbtoloczko's Avatar
sans SVX
tire pressure/wear observations...
I think I'm running more tire pressure than necessary, at least for daily driving conditions. I just rotated the tires last weekend after ignoring them for about 5k miles, and since I'm running more negative camber than stock (settings are -0.8 deg camber front, -1.1 deg camber in the rear), I was expecting some inside tire wear. To my surprise, there was no noticeable inside tire wear, but there was significant middle tire wear which is indicative of too high a pressure for the weight of the car. I've only been running between 36-39 psi in the front and 32-35 psi in the rear. I guess that's more than necessary for daily driving that consists of just driving around town and highway driving. Tires are 225/45-17's mounted on 7.5" wide rims.
Mychailo
Visit my locker
Old 11-15-2003, 04:53 AM
i would say so. i barely run about 30 per.
and my wear is quite even.
Old 11-15-2003, 12:49 PM
To keep the circumference the same, or the distance from the top of the wheel to the ground, it takes that much difference in pressure. I will be watching how mine wear.
Old 11-17-2003, 05:58 AM
svx_commuter's Avatar
Re: tire pressure/wear observations...
What brand/model of tire are you using?
SuperbVehicleXtraordinary
Proud sponsor of a 1992 SVX.
Old 11-17-2003, 08:30 AM
mbtoloczko's Avatar
sans SVX
Re: Re: tire pressure/wear observations...
Sumitomo HTR+. Its a great tire except that its incredibly loud.
Mychailo
Visit my locker
