Old 06-21-2003, 09:54 AM
SVX ROO SVX ROO is offline
Question Exhaust Noise Re-visited
Both my '92 and '94 have identical exhaust noises. I concentrated on the '92 because iut also had a leak. I have replaced the leaky pipe (left front cat') and all new gaskets. I have NO leaks now. I also relaced or repaired all of the heat shields so they are not rattling.
I have heard that there is an internal baffle that breaks loose and can cause this noise. Noise occurs at part throttle, mainly light acceleration. It goes away at idle and half + throttle.Noise is definitely near center of car.
I have listened with a hose and can not be sure where noise is coming from, definitely internal. Does this baffle problem occur in the Y-shaped, 2-into-1 cat' or in the first silencer just behind it?
Ken
'92 Pearl
'94 Bordeaux
'69 Lotus Elan +2 with Cosworth BDR
Old 06-22-2003, 07:32 AM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
How did you repair all of your heatshields?
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 06-22-2003, 07:11 PM
heat shields
Most of the bad heat shields were on the primary cat' that I replaced. The pipe comes with all new shields, for $360! The remaining shields were OK except for one of the welds on the U-piece. I put a layer of fiberblss heat shield beteen pipe and shield and it bolted up tight and no vibration. I don't know how long it will last but it is not rattling.
Ken
p.s. It is a little scary laying under an SVX on jack stands with motor running and car in gear and all 4 wheels spinning with wife blipping throttle to make the noise !!
Old 06-22-2003, 07:39 PM
Mr. Pockets's Avatar
Moderator
Re: heat shields
Ken
Oh, yeah, that wouldn't look suspicious.
'Ma'am, you say that your husband laid under the car and asked you to step on the gas???'
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 06-23-2003, 06:30 PM
and the answer is.....
Lots of nice postings but I was hoping somone had an answer to the original question. Whcih of the two boxes is known to make the noise. The 'Y'-shaped cat' or the first stage muffler?
Old 06-23-2003, 07:33 PM
gl1674 gl1674 is offline
The resonator is known to be prone to make the noise. I guess you may call it the first stage muffler.
Old 06-25-2003, 06:47 PM
thanks
GL
Thanks, a real answer to my question. I'll try it on one car and see if it works.
Ken
Old 06-25-2003, 07:21 PM
mbtoloczko's Avatar
sans SVX
Re: and the answer is.....
The Y-cat heat shield made noise on my car.
Mychailo
Visit my locker
Old 06-27-2003, 01:44 PM
elninoalex's Avatar
elninoalex elninoalex is offline
Registered Abuser
I replaced my "2 into 1" cat with an aftermarket, with just straight pipes in front of it. It rattled like crazy. Dynomax sent me another one, and it did exactly the same thing. So I welded in some glass packs right after the o2 sensors and BINGO, no more rattle. It sounds absolutely unbelievable now.
Stephen
92 Ebony - Level 10/n2o REAR-ENDED
92 Teal - painted yellow/4.11 5spd/n2o SOLD
92 Claret - 4.44 SOLD
94 Barcelona - FWD SOLD
92 Ebony - 3.90 SOLD
94 Laguna ROLLING w/4.44s/Ecutune ECU +TCU/STI springs/Infiniti M45 rims
Old 06-27-2003, 02:25 PM
emissions??
Stephen
Have you stopped at your local emission test facility lately? It would be good for us to see the results.
Ken
