Old 06-22-2003, 05:21 AM
paddlesnz's Avatar
paddlesnz paddlesnz is offline
Send a message via Yahoo to paddlesnz
'How to' for 4WS codes
For those very few who have RHD and 4WS, here are the codes for deciphering the 4WS check light.
1) Remove the kick panel just beside accelerator pedal.
2) Locate blue wires.
3) Locate black connector. Hold it so that the notch is up.
4) With ignition off, insert one (either one) of the blue wires into top row, 4th pin from left. (The black connector has 4 pins in the top row and six in the bottom row)
5) Turn key to on position, but do not start the car.
6) Watch flashing 4WS light on dashboard. Count blinks. Long blinks = 10, Short blinks = 1.
7) Keep watching flashing light until you have remembered the code/codes
CODE PROBABLE CAUSE
11 Speed sensor - cut/short
13 Steering Wheel Angle Sensor - off centre
14 4WS ECU - no power
21 Steering Wheel Angle Sensor - cut/short or sensor failed
22 Steering Wheel Angle Speed Sensor - cut/short
31 Rear Wheel Steering Sensor and Motor - failed
32 Rear Wheel Steering Sensor - cut/short@or sensor failed
33 Rear Wheel Steering Speed Sensor - cut/short or sensor failed
34,37 Rear Steering Motor - no power
35 Rear Wheel Steering locked due to short in Steering Motor
36 Rear Steering - Left/Right Lock has been exceeded.
41, 43, 44 4WS ECU failed
42 Rear Wheel Steering Motor - no power due to blown fuse
45 Rear Wheel Steering Motor short, ECU failed
To clear codes (after problem has been resolved):
1) Ignition 'OFF'
2) Remove Fuse SBF7 (4WS) from Fuse Box in Engine Bay. Wait 5 minutes.
3) Reinsert fuse.
4) Recheck as above to ensure all codes have been cleared. No codes = steady blinks at 1/4 second intervals.
paddlesnz
1993 Subaru Alcyone SVX
1980 Isuzu 117 Coupe Giugiaro Edition
1999 Mazda Astina
2006 Honda Legend
2006 Toyota Mark X Premium
2007 Toyota bB
2007 Mazda Roadster RS
2012 Peugeot 208 Allure
Old 06-22-2003, 08:44 AM
Phast SVX's Avatar
Phast SVX Phast SVX is offline
BOOOOOOOOOOOOOOOOOST
Send a message via AIM to Phast SVX
paddlesnz,
you never cease to amaze me. I hope this solves the new guys problem, thanks for taking the time out of your day to look into that.
sincerly
phil
~Phil
Teal 1992 Subaru SVX Turbo - Sold in May 2011 to peace-frog.
Old 06-24-2003, 03:21 AM
Trevor's Avatar
Trevor Trevor is offline
Greetings Paul,
Long time no see. Thanks for the info and good to see that you are still looking in here.
I am expecting a visitor regarding the problem and hope I can be of some assistance but do not like the prospect of trying to sort out such a well worn and multi owner car. If it looks expensive best thing will be to lock up everything if that can be done easily.
When are you due home again ?
Regards, Trevor.
Trevor, New Zealand.
Old 06-24-2003, 04:04 AM
paddlesnz's Avatar
Originally posted by Trevor
Greetings Paul,
Regards, Trevor.
I'll be back in NZ in just over a month for a couple of weeks. Looking forward to driving my SVX again after a year in storage.
paddlesnz
1999 Mazda Astina
2006 Honda Legend
2007 Toyota bB
Old 06-24-2003, 08:19 PM
Trevor's Avatar
Greetings Paul,
If we can meet up again let me know. I think and trust you have my 'phone number and email. If not send a PM.
The SVX will be looking forward to some exercise. What about a bash up this way ? Possibly I still hold the Auck./Wgtn. record !
Regards, Trevor,
