Old 05-17-2003, 01:08 PM
mbtoloczko's Avatar
sans SVX
door light timer module location...
In case anyone is wondering, the door light timer module for '94+ SVXes is located to the *right* side of the glovebox. Its tucked pretty far behind the dash, but with a bit of patience and some hand gymnastics, its possible to get it out just by removing the glovebox alone and removing the screw holding the module to the car.
BTW, the exterior design of '94+ timer modules is slightly different than the exterior design of '92-'93 timer modules, but the guts are identical. Since its easy to access the guts, if you need to replace the module, a used one from any model year will get the job done.
Mychailo
Visit my locker
