Old 05-26-2009, 08:48 PM
Re: How To Do the Bosch Relay Mod???
Originally Posted by dannmarr View Post
Here is another diagram and a photo of the installation.
#30 positive
#86 negative
#87 starter
#85 to wire that was removed from starter
The supply for the relay is best obtained by making a connection at the main starter terminal, which is connected direct to the battery. Otherwise an extra wire, not protected by a fuse will have been introduced.
Old 05-27-2009, 04:49 AM
pearlm30's Avatar
pearlm30 pearlm30 is offline
Do you happen to have the part number of this relay? Do Autozone or Advanced autoparts carry it?
BTW What size of wire(AWG) do you use?
Thanks
Here is a write up with photos;
http://svx-iw.com/svxiw/article/?article=196
94 Bordeaux Pearl SVX Lsi B&M cooler with Aux ATF filter. QC Kit Plus 06 Sti Gold Wheels. SOLD
92 Claret WRX 5 speed ECUTune 1AV1 Gold STI Wheels & more. SOLD
92 Teal SVX LSL lowered with Konig. SOLD
92 Black SVX LSL with B&M cooler & Aux filter. Small Car Shift Kit. Gone
94 Red SVX L FWDwith LSL Leather Interior. SOLD
92 Teal SVX LSL....with B&M cooler & Aux filter. Small Car Shift Kit. SOLD
95 Polo Green........With Trany Problem. GONE
Almost complete Rear Wheel Bearings Job with Pictures in my locker
My Locker http://www.subaru-svx.net/photos/user.php?pearlm30
Old 05-27-2009, 04:50 AM
pearlm30's Avatar
Thanks a lot everyone!!!
Old 05-27-2009, 05:10 AM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Yes, this is a great idea. I believe Harvey mentions this in his diagram. Thanks.
Old 05-27-2009, 05:17 AM
dannmarr's Avatar
I work for my SVX
Thanks
I don't have the part number, it's a 30 amp relay
and I used 12 gauge stranded wire.
Old 05-27-2009, 07:00 AM
I plan to employ this setup for my Ebony during my inspection and replacement of any deteriorated wiring. I also will install it on Jon's Laguna before we take the car on any trips this summer.
I did experience a similar start issue with my Claret, but when I was checking wiring during the engine swap I found a crimp in the battery cable. Once I replaced these wires, I no longer had the problem. I will most likely install the relay anyway once I redo my alternator wiring.
Old 05-27-2009, 09:12 AM
LetItSnow's Avatar
Still Cant' Say the Z-Word
Originally Posted by Starter relay bypass installation, Author: Dannmarr
ALERT! With this installation, DO NOT shift into park or neutral while the cruise control is activated. The cruise control is grounded through the starter and will activate the relay and starter again! Just remember to deactivate the cruise control before you use park or neutral.
Surely, there's a way around this.
Old 05-27-2009, 11:06 AM
immortal_suby's Avatar
Thread Killah
Thanks
Advance had 30 amp relays part # 84601 Conduct Tite brand. (no bosch)
I also picked up a 30 amp inline waterproof fuse holder made by Bussman
edit: is the 30 amp fuse necessary if you connect at the starter terminal for power?
Locker Link
2015 BRZ Limited 6MT
Old 05-27-2009, 12:25 PM
Thread Killah
Just finished installing it. Works great! Thanks guys.
Locker Link
Old 05-27-2009, 02:12 PM
pearlm30's Avatar
So where did you get your power? Do you ended up with a 30 amp fuse?
Thanks
Old 05-27-2009, 03:08 PM
No you do not then need the fuse. The relay coil would safely burn out if there were shorted turns and the location is safe.
In any event, a 30 amp fuse would not protect the relay or a light wire, as is only required for a connection to the battery. Any fuse fitted should be as close as possible to the battery end of the wire. I note from where this strange specification originated. Perhaps it was assumed that the relay draws 30 amps.
Old 05-27-2009, 05:14 PM
That was a problem that some found, when they used a relay that had a high resistance winding that could be energized by the Cruise Control Deactivation circuit that uses the starter solenoid to turn off the Cruise when P or N is selected.
As long as the type of relay is a 30 amp and has a armature winding resistance, of about 100 Ohms or less, you will not have a problem.
Old 05-27-2009, 06:02 PM
Do not ask for a relay with certain "an armature winding resistance", as there is no such animal. The armature comprises the moving magnetically attracted part of a relay. Coil resistance, is the usual term.
Old 05-27-2009, 07:15 PM
Thread Killah
Thanks
I got power from the starter, at the 12mm nut.
I did not use the fuse, as Trevor noted it is not needed if you get power there.
Locker Link
Old 05-30-2009, 04:29 PM
LetItSnow's Avatar
It's staggering how awesome it feels to be able to turn the key one time and have the engine turn... every time. This should surely be on the <$100 Mod List, possibly one of the first things that should be done to a newly-bought SVX, and likely a kit-worthy project, if proper wiring can be agreed to.
I put my relay on the cruise control bracket as shown elsewhere, but I grounded it to the bolt that holds it in place. The multitester showed the mounting threads and the battery ground to have practically no resistance, and it works fine.
No more snickering for my Subaru comrades around town!
