Old 11-04-2007, 07:20 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Dash door light indicator
When I open my doors the indicator light on the dash does not light up. Because of this, the alarm does not know when a door is opened. What should I do?
Old 11-04-2007, 10:31 PM
Manarius's Avatar
Manarius Manarius is offline
I'd check to see if the sensor at the door itself is stuck.
-Jason
-Obi Wan Kenobi
Old 11-05-2007, 06:51 PM
dannmarr's Avatar
I work for my SVX
Actually, when the door is open, the inside light doesn't light up either . I pressed the 'door' button above the rear view mirror and nothing happens. Is it a fuse or a relay? Where are they located?
Old 11-05-2007, 06:57 PM
crazyhorse's Avatar
242,000 mi on oem trans
Does the passenger side indicator work? Does the dome light come on when you hit the "roof" button?
These door sensors, are they magnetic? I don't see a switch like any other reasonable car LOL
"42"
Current Stable By Age:
Old 11-06-2007, 04:08 AM
The switch is a part of the latch mechanism. You need to take the door apart to check it out.
Old 11-09-2007, 06:10 AM
dcarrb dcarrb is offline
Do you know if the entire latch assembly has to be replaced? My dome light and belt have started acting as if they're on a delay, and I figure the switch must failing.
dcb
Old 11-09-2007, 07:30 AM
It could probably get cleaned out with some contact cleaner??? I think, I have one out of a door, I'll get a picture if I do...
Old 11-09-2007, 08:07 AM
Thanks. Near as I could tell from a parts diagram, the switch isn't sold separately, and the latch assembly is $100+. I'll definitely zap it with some CRC before springing for a new part.
dcb
