Old 10-18-2007, 08:31 PM
bricud bricud is offline
Unhappy Engine knock
I have a 1994 svx with a knock in the engine at around 1800-2000 rpm. I discovered after I removed the rattling exhaust heat shield. My manual tells me it is most likely a rod or crank knock. The engine drives fine, so I was planning on just driving until it gets worse, then buy a good used engine. Anyone out there had this knock and found it to be something else?? Also, where is a trustworthy place to get a good used engine with low miles?? Thanks.
Old 10-18-2007, 09:43 PM
redsvx's Avatar
redsvx redsvx is offline
Alcyone ... the brightest star
you could try to search this forum or take a look at this thread
http://www.subaru-svx.net/forum/show...ighlight=knock
it could be something as simple as put in a new oil pump, change to synthetic motor oil, or higher octane gas
92 SVX LS Pearl
94 SVX LSi Barcelona Red
82 Brat 4WD
Bob
