Old 10-15-2007, 12:14 AM
svxual's Avatar
svxual svxual is offline
no power to my passenger door??
i appear 2 have no power 2 my passenger door the window dont wrk and the central locking dnt work that side either,, the window isue has worsend over time i was told by old owner it used 2 work then would only go down but not up but it works fine using the driver controls.. and the door light still works
i tried a new window switch but that didnt help i it was a working one i swapd it out of a m8s while we were getting our tints.??
Old 10-15-2007, 05:08 AM
There is a connector in behind the kick panel on that side that feeds the door...check it out, look for bad spots in the loom from that connector to the hole in the body it goes through, if the rubber boot is not in place correctly, it couild have chaffed through and shorted out the door loom..
Old 10-15-2007, 05:33 AM
svxual's Avatar
Smile
ok that being which side kickpanel? mine is right hand drive.thanx
Old 10-15-2007, 06:27 AM
svxual's Avatar
k had a look and couldnt find any damage 2 wires etc ,mite find me tester and have a prod around
Old 10-15-2007, 08:07 AM
The one by the affected door...
most likey if that looks good, it is in the door loom
