Old 10-14-2007, 02:54 PM
Another dead Trans???
Well, the trans in Melis's car has started acting up after about 3 weeks.
About a month ago, I removed the trans to replace the front diff. While it was out, I adjusted the brake band to spec (6'#'s then back 3 turns).
For a few weeks it shifted great, in all gears, smooth as can be. Earlier this week she mentioned that it would slip in 1st and 2nd under hard acceleration. I told her to try it with the selector in 2nd, and that seemed to help the slipping. By the time I got here to look at it on Thursday, it was starting to slip no matter where the selector was.
I checked all the lines for kinks, pulled the resistor and tightened the brake band about a turn. I also checked her TPS, there was a dead spot, just above idle, so I swapped that out.
It is slipping in all gears, including reverse. It seems like it's not getting pressure.
I'm getting it towed to my place so I can pull the pan and check the internal filter. Anything else I should check??
Old 10-14-2007, 03:56 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Dave/Melis,
Sorry to hear about the trans...slipping in all gears is not a good sign...
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 10-14-2007, 04:00 PM
make sure there is a good o-ring on the filter... If not you are sucking bubbles
Old 10-14-2007, 04:03 PM
wawazat??'s Avatar
Yeah, I'm still around
Sucks Dave and Melis. Sorry
Down to none
Old 10-14-2007, 04:27 PM
crazyhorse's Avatar
242,000 mi on oem trans
Melis must be fit to be tied! After all, she just got Peej back on the road.
"42"
Current Stable By Age:
Old 10-14-2007, 06:42 PM
Replace the main line pressure control solenoid (A) while you are at it and reconnect the resistor.
If you do this please report the result.
Old 10-14-2007, 06:52 PM
The tow truck just dropped us off. I'll be digging into her tomorrow.
I'll check that out.
I have a few tranny's around, is there a way I can check that solenoid to make sure I put a good one in?
Old 10-14-2007, 06:55 PM
Dave, worste case scenario, I know where to get some 5mt parts
tom
Old 10-14-2007, 09:48 PM
94SubieSVX's Avatar
OOC for a while
Dave, best case scenario, I know where to get some 5mt parts
tom
Fixed it for you
bLAh
Old 10-14-2007, 10:21 PM
It would be best to fit a new solenoid.
However you can check that there is no debris which could be preventing it from closing properly. Give it a careful wash through in petrol or whatever, while operating it.
Apply 12 volts to the coil and as you operate it on/off, blow through it as a means of testing that the valve and seat are clear, undamaged and sealing properly. It will not taste nice but what the hell.
Not a positive test as normal pressure will not be applied, but still worthwhile. If you have access to compressed air, use it for both cleaning and testing.
Old 10-15-2007, 05:13 AM
JaySVX's Avatar
JaySVX JaySVX is offline
tom
You leave my car alone! NOT available for parts...
*No SVX at the moment...*
1987 Winnebago Elandan 35'
2001 Yamaha Roadstar 1600
Old 10-15-2007, 10:22 AM
Well it's a good thing the asshole that did her last tranny job warranties his work
Before I tore into it today, I decided to doublecheck the ATF level... the dipstick's dry. I just checked it before the issue started and it was full. It did not leave 3+ quarts of ATF on a puddle or in a cloud.... Check the front diff, it's full of redness
So I drain the diff and refill it with not ATF'd gear oil. Add 2 quarts of ATF to the trans and take it for a little drive. She shifts like a dream
So... back off with the trans, back off with the front diff and use NEW seals. What do I need?
I know I shouldn't have reused that tube with the rubber on each end (I did used permablack on it )
What other seals do I need, I don't want to do this again.
Old 10-15-2007, 10:24 AM
its probobly the pinion seal.... Thats my guess
Old 10-15-2007, 10:28 AM
I know 9 and 16 on this diagram (I did replace 9 the first time )
Any others??
How about anything from this diagram?
Old 10-15-2007, 10:33 AM
I think only 20&21
