Old 10-07-2007, 05:15 PM
BeneathNorthernSkys's Avatar
BeneathNorthernSkys BeneathNorthernSkys is offline
Work, Sleep, SVX, Repeat
Speedometer no longer reading, have a cracked radiator..
ok so my radiator has been cracked, and I've known for like 3 weeks. Today about an hour ago my speedometer stops working, my power button flashed like...21 times or something. I really don't remember, and the check engine light is on. I checked oil and stuff, nothing wrong there. I'm suppose to be driving to portland and back tomorrow. I just worry about hurting my car. Anyone's thoughts on this would be helpful. For the record, svx's are really expensive
* I started up my car to see how many times the power light blinked...and I believe it was 21 times. So it's an ATF issue...I guess? I don't know how expensive this is to fix..but I pray to god it can be done in a couple hours and easily.
Old 10-08-2007, 03:33 AM
subarufamily subarufamily is offline
do a search for transmission codes it will tell you which code breakdown is , if you allowed your radiator to go low/dry you might have fried your tranny they like and i mean really like to overheat and burn up
Old 10-08-2007, 05:15 AM
msvx95's Avatar
msvx95 msvx95 is offline
It's just a phase
List of TCU Trouble Codes
Trouble Code Item
11 Duty solenoid A
12 Duty solenoid B
13 Shift solenoid 3
14 Shift solenoid 2
15 Shift solenoid 1
21 ATF temp sensor
22 Atmospheric sensor
23 Engine revolution signal
24 Duty solenoid C
31 Throttle sensor
32 Vehicle speed sensor 1
33 Vehicle speed sensor 2
There you go....ATF temp sensor faulty. Check http://svx-iw.com/ to find out your codes.
Get your radiator fixed....you will do damage either way with a short or long drive.
Hope that helps
1995 Subaru Svx L / AWD
Old 10-08-2007, 01:16 PM
thank you for the list hope it helps him
Old 10-08-2007, 08:32 PM
I would think that you do not have to be told to keep a close eye on your engine temperature and coolant level.
Code 21 only indicates a faulty transmission temperature sensor, rather than actual excessive transmission temperature.
N.B. Check the code again. I would expect a trouble code 32 or 33, resulting from a speed sensor fault, there being two sensors with only one involving the speedometer. I can not advise which as US and my DM are different. Failure of one is backed up by the other in respect of transmission functions, so that a problem in this area will not be apparent.
If you can establish that you have only a speed sensor problem, you will not cause any damage. However if the code is "21" correct indicating a faulty sensor, you could have doubts regarding transmission temperature as the cooler is part of the radiator.
Old 10-15-2007, 06:17 AM
svxual's Avatar
svxual svxual is offline
about the radiator having the trans cooler inbuilt ?? how do ya top it up after changing radiators i had to get a new steel top on mine after the plastic one said game over??
Old 10-15-2007, 06:32 AM
JaySVX's Avatar
JaySVX JaySVX is offline
You need a funnel with a long hose, about 1.5ft in length. You fill it where the dipstick is on the tranny, near the firewall on the driver side, all the way down in there. Test your fluid level with the engine running, in park, on level ground. Add fluid with the engine off i believe. Any local hardware store will have the funnels for about 2$, just put the hose down in the hole the dipstick came out of and fill it up.
*No SVX at the moment...*
1987 Winnebago Elandan 35'
2001 Yamaha Roadstar 1600
