Old 03-11-2005, 08:16 PM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
Thumbs up Hmmm...time for 4.444 gears!
Well, my 4.11 trans went out after 7-8 months of drag racing on it. After noticing my 1-2 shift was occuring at redline over the last month (Harv had mentioned it was due to a slipping band), I lost 2nd gear this morning followed shortly by fourth.
I think what killed it wasn't that I broke a gear (haven't heard any grinding, etc), but that I was driving around on it for several months will the brake band not properly adjusted (which wore it out prematurely).
Either way, it's time to rebuild, and I'll be ordering a '96 Legacy Outback 4.444 4EAT and matching rear diff from Tom's (svxfiles) parts guy on Monday.
I should be back at the drag strip in 3-4 weeks and it'll be interesting to see what improvement these gears will have in dropping my 1/4 mile et...
-Chike
My name is Chike and I'm addicted to drag racing...
2006 Steel Gray WRX TR (sold)
Old 03-11-2005, 09:03 PM
Weasel 22
best of luck...im interested to see the difference with the gear change
and at least you know why the tranny went
Old 03-11-2005, 09:58 PM
Amazonparrot's Avatar
Amazonparrot Amazonparrot is offline
Now with Colder Air!
Send a message via AIM to Amazonparrot Send a message via MSN to Amazonparrot
Lightbulb
Chike, sorry i missed your call this evening, sorry to hear about your tranny, its seems as though we are in the same boat now Give me a call tommorow after 5 if you get the chance, ill be putting my new wheels and tires on the car. Also, keep me posted on all the prices and parts availbility through Tom's guy, b/c i might be ordering one myself if things don't improve by adjusting things. Talk to you later, and the best of luck!
1992 Subaru SVX LS-L Ebony Mica: Custom Cold Air Intake, Smallcar Shift Kit, ECUtune Stage 1v4, Flowmaster Exhaust, UR underdrive pulley, 4.11 gears, iRotors Drilled and Slotted rotors, Axxis Brake Pads, 18" Enkei Wheels w/Pirelli Pzero Nero M+S, 20% Window Tinting, K&N Panel Filter, Rockford Fosgate Sound System w/XM Radio, Removed Intake Resonator *SOLD*
2003 Subaru WRX: 2003 Impreza WRX (Aspen White); Vishnu Stage II; IHI VF-34 Turbo; Walbro fuel pump, STi Injectors, Vishnu Up-pipe, Down-pipe and Signature 3" Cat-back; Samco Intercooler hoses; JIC Coilovers; STi A-arms; Whiteline swarbar bushings; Stoptech 13" rotors w/4-piston calipers; Braided Steel brake lines; 17" Rota Wheels with 225/45/17 Falken Azenis (R-Comp).
Charlottesville, VA Represent! (voted #1 place in America to live!)
http://www.subaru-svx.net/photos/user.php?Amazonparrot
Old 03-11-2005, 11:50 PM
Chiketkd's Avatar
Andrew,
I'll give you a call tomorrow when I get the chance - will be pretty busy with the wife and kids all weekend though.
I'll let you know about prices, but remember the switch to 4.11 or 4.44 gears will typically run you at least $450-$550 for the trans & diff.
His parts guy does have a '96 Impreza trans for sale for $275, and I could sell you my 4.11 rear diff for $50 (already grinded out to accept the SVX ltd slip hub) which will put you at $325 + fluids + gaskets if you went the 4.11 route.
4.44 trans and diffs generally run between $400-$500 for the trans and another $100 for the diff.
-Chike
Old 03-12-2005, 08:26 AM
mbtoloczko's Avatar
sans SVX
Hey Chike,
Are you going to tear apart the old tranny to see exactly what stopped working?
Mychailo
Mychailo
Visit my locker
Old 03-12-2005, 08:50 AM
Chiketkd's Avatar
Originally Posted by mbtoloczko
Hey Chike,
Mychailo
I'll be doing the swap at Tom's place. I'm all but certain the band just wore out completly on it, but if Tom wants to tear into it, he's more than welcome to...
They are some items that are in excellent condition that I'll be keeping though - rear transfer clutch assembly, 4.11 front diff, etc. This trans only has about 30K miles on the rebuild that Huck369 did.
-Chike
Old 03-11-2005, 11:43 PM
Chiketkd's Avatar
Thanks Shawn!
The shorter gearing should definitely improve my launch & 60' times. Hopefully from doing this gear swap, I'll be solidly in the 14's.
Yeah, it's definitely good to know why the trans failed. I plan to do a brake band adjustment on the Outback 4EAT before installing it, to make sure everything is at the factory setting.
-Chike
