Old 04-25-2005, 07:44 PM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
As long as the oil is changed regularly the oil pump should outlast the engine - it's self-lubricating. (psssst...the dealer guys love to hose ya when there's a leak at the o-ring)
Old 04-25-2005, 08:51 PM
immortal_suby's Avatar
Thread Killah
That's good news, Beav. I guess I am just too paranoid when it comes to these things. Went through too many oil pumps on the old 1.8L. Sounds like they have fixed that problem on the svx.
Locker Link
2015 BRZ Limited 6MT
Old 04-25-2005, 09:09 PM
Treppiede Treppiede is offline
Matt, don't be sorry, I would rather get the harsh news trown at me right now than have to pull my hair 20k miles from now... I must admit however that Beav's words are much relieving.
Update with the current situation: I have purchased the pulleys and tensioner from Tom. He will ship the stuff to me hoping that I receive it on time for the weekend.The components are obviously used, however according to Tom they were operating correctly before the engine was pulled out, so I decided to go with it since I am broke.
I know many of you will tell me that I should have gone with brand new components and I agree with you, but right now I decided this was the best solution...
Anyways, I was wondering if you guys could recommend me a way to clean the used components that Tom is sending me... perhaps I could clean the pulleys with electric parts cleaner and add some fresh grease similarly to what I have done with the rear bearings?
Thank you,
Walter
1995 SVX Green - now 5spd! ..::|SOLD|::..
1991 Talon TSi AWD (~400 whp pump gas)
1993 Civic CX Hatch (daily driver)
1999 Ducati 748S (built 996 engine)
Old 04-26-2005, 10:22 AM
Beav's Avatar
Not as old as Randy
Didn't I see a TSB some time ago about the pumps on older, 4cyl. cars being defective and pushing the front seals out?
Old 05-02-2005, 06:49 PM
Hey Guys,
I finally got all the parts I need to get her back together and I am getting ready to do so. I already took some good quality pics and I will post them later on tonight for you guys to see.
In the mean time, I have a couple of questions:
- How much should I torque down the bolts for the pulleys? I already saw the torque settings for the tensioner and crank pulley, they were on the tutorial you linked me to, all I need is the torque specs for the pulleys and the cam gears.
Thanks, I will post later on tonight with the pics of the damage (it looked crazy)...
Walter
Old 05-02-2005, 07:42 PM
Originally Posted by Treppiede
Hey Guys,
Walter
all those #'s should be in the cd's i sent to you
Old 05-02-2005, 08:24 PM
I'm pretty sure they are, but when I posted that I was at my friend's shop and of course I didn't have them with me... but now I am back home, ready to take notes and show you some pics of the damage:
So that's what I am looking at. Today I only managed to remove all the pulleys and tensioner, I also tried to remove the water pump but it seems to be stuck behind that plastic cover behind the cam gear. I tried removing the cam gear but of course it turned out being impossible, so I will have to buy some sort of tool tomorrow before trying again. What should I ask for? All I need is something to stop the cam gear from turning while I loosen the bolt.
Anyways, let me know what you guys think. I will work on it again tomorrow after work.
Take care,
Walter
Old 05-03-2005, 10:02 AM
dddddddddddddddddddddddaaaaaaaaaaaaaaaaaaaaaaaaaaa auuuuuuuuuuuuuummmmmmmm That is crazy lookin!!! Godd thing you got all da parts tp put it back together.
Old 05-03-2005, 11:38 AM
Yup...
Anyways, back to the water pump... I won't be able to swap it until I remove the cam gear... it looks like I will have to buy some sort of tool tomorrow before trying again. What should I ask for? All I need is something to stop the cam gear from turning while I loosen the bolt.
Walter
Old 05-03-2005, 02:35 PM
people usually make their own tool for that. I personally just left the timing belt on when I loosened them. then tookt he belt off and they would just come right out. I dunno what u should do bout that, ask around someone may have a solution 4 ya
Old 05-03-2005, 02:48 PM
It would be cheaper to replace the entire engine with a used one.
Old 05-03-2005, 02:51 PM
how so? He spent $100 on parts to fix it. Shipped to his door.
Also, i have heard that the pump will come out even under that cover, just takes patience and a little jigglin.
Old 05-03-2005, 06:16 PM
Thread Killah
I just threw up in my mouth.
Holy carp man! That is some serious damage.
Locker Link
Old 05-03-2005, 07:33 PM
Holy crap man! That is some serious damage.
Yeah, looks nasty but the engine is healthy. The cam gears spin around smoothly, so I am not worried about the valvetrain (don't ask me how I know that the cams turn so easily)...
...which reminds me:
That is true, with a little patience and jiggling today I realized it would have come out, although I am too afraid to break the plastic cover behind the cam gear so as Mike (longassname) suggested me I will try the tool he lent me to remove the crank pulley and see if it fits...
Walter
Old 05-04-2005, 03:47 PM
I'll try again
It would cost more to buy NEW replacement parts than it would a used engine.
