Old 09-03-2004, 06:21 PM
SubaRyu's Avatar
SubaRyu SubaRyu is offline
Domo Arigato
Replace or Resurface?
So my brake started to vibrate a lot espesially when I brake from high speed, say 60-80mph. Sometimes that scared me off... This doesn't happen so much with low speed or when its cold.
Rotors warped?
I'm thinking still... should I get new rotors? or resurface the rotors? If I resurface it, will the same thing happen again?
If anyone knows good new brake rotors or solution, I would really appreciate to hear!!
Thanks
-Ryu
-Ryu
Links:
2004 Honda S2000 (2008~)
1992 Subaru SVX LSL Liquid Silver (2007~2008)
1996 SVX LSi Bordeaux Pearl (2006~)
2002 Lexus IS300 Sportcross (2005~)
1992 Subaru SVX LSL Pearl White (2001~2005)
1994 Mercury Sable GS (1999~2001)
1/43 Scale SVX Models
[SIGPIC][/SIGPIC]
Old 09-03-2004, 07:50 PM
My Race Concepts cadmium plated, dimpled and slotted rotors are still not warped after a year and a half of hi speed and hard braking. With their pads, stainless steel lines it's almost as much fun to stop as it is to go!! And absolutely no brake dust. Tom
Old 09-03-2004, 10:25 PM
Bxsvx Bxsvx is offline
How fast is fast?
Send a message via AIM to Bxsvx
Is your ball joints in good shape? I thought my rotors were bad also, drive at high speeds and then when I brake, it shudders etc... So I changed my ball joints because I knew it they were bad to begin with, now the rotors are excellent no fading, no shuddering. Good luck
Old 09-04-2004, 01:35 AM
Gargoyle's Avatar
Gargoyle Gargoyle is offline
The Croupier
Ditto Ditto Ditto & Ditto ( Except for I do get a small amount of brake dust )
If you call raceconcepts about parts be sure to tell them you where refered from here & you will get a good price. I got the lines for my birthday & I bought the rotors & Pads & I think all 4 rotors & pads was around $ 300 & worth every cent..
Anycar that can get up to speed & go as fast as our cars can , really NEED's to be able to stop as fast as it gettiups
Gargoyle,, AkA-- Allen
92 SVX LS-L 80,^^^
90 Mazda B 2200 (the dog & boat towmobile) 226,^^^
03 Yamaha V-star custom /classic 3k
Old 09-04-2004, 12:03 PM
SubaRyu's Avatar
Domo Arigato
Thanks guys for the info.
I just checked out the Raceconcepts website.. are these the one you guys were talking about?
So, so far nobody voted for resurfacing the rotors??
-Ryu
Links:
[SIGPIC][/SIGPIC]
Old 09-04-2004, 12:06 PM
SubaRyu's Avatar
Domo Arigato
Oops, I thought I attached the price image.. hope the image will be attached to this thread..
-Ryu
Links:
[SIGPIC][/SIGPIC]
Old 09-05-2004, 10:35 PM
BoondockSVX
Rotors do not warp. You have overheated your pads. Get your rotors resurfaced, and use some high performance pads. Your problems will be gone.
- Jim
Old 09-06-2004, 05:04 PM
seasvx's Avatar
seasvx seasvx is offline
ok, i will. bought the car w/38K and slowly over the last 3 yrs front brake vibration kept increasing. was ready to go the new cryo-rotor route, took it into Smart Service instead, they checked the rotors, found enough material to resurface, did it, gave the car back to me for $150, problem gone.
Old 09-06-2004, 09:41 PM
BoondockSVX
HOLY CRAP! You got served. I take my rotors to a local car parts store.... Resurfacing is $15 each.
Old 09-07-2004, 01:16 AM
HighwayUFO's Avatar
HighwayUFO HighwayUFO is offline
After 200, it's all the same.
- Jim
Um...Yeah, rotors do warp. It may not look like it, but yes they do. I have one that is off the SVX and it doesn't lay flush on a flat surface.
Keith
The member formerly known as Civic_Slayer
1992 "Robins egg blue" SVX Originally Claret 147k- CURRENT
1992 Pearly 187K and climbing (11-91) #964 *retired
1992 Pearl SVX 122500 miles #86 FASTAR THAN THE OLD ONE.*SOLD
Everytime I get into my car, it always reminds me that it has POWER
Old 09-07-2004, 10:57 AM
BoondockSVX
Keith
That isn't warping. What happened is that your pads deposited unevenly on the surface of your rotor, and under high heat, the cast iron begins to absorb the material and become cementite, an iron carbide. Since cementite is very hard, it does not wear like a normal rotor, so other parts of your rotors are wearing normally, and the cementite is not wearing much at all. This is why your rotor will not sit flush on a flat surface: One part is worn, the other is cementite.
Rotors do not warp.
- Jim
Old 09-07-2004, 10:59 AM
BoondockSVX
Forgot the link:
http://www.stoptech.com/whitepapers/...otors_myth.htm
I'm pretty sure he knew more about braking systems than you or I ever will.
