View Poll Results: Have the rear wheel bearings on your SVX ever failed?
1992 SVX w/ no bearing failure 12 19.35%
1992 SVX w/ bearing failure 28 45.16%
1993 SVX w/ no bearing failure 3 4.84%
1993 SVX w/ bearing failure 0 0%
1994 SVX w/ no bearing failure 5 8.06%
1994 SVX w/ bearing failure 1 1.61%
1995 SVX w/ no bearing failure 1 1.61%
1995 SVX w/ bearing failure 7 11.29%
1996 SVX w/ no bearing failure 1 1.61%
1996 SVX w/ bearing failure 3 4.84%
1997 SVX w/ no bearing failure 1 1.61%
1997 SVX w/ bearing failure 0 0%
Voters: 62. You may not vote on this poll
Old 08-19-2004, 11:31 AM
dcarrb dcarrb is offline
footnote
Regarding replacement on my car, the left bearing and seal set was from Subaru (gratis, from the dealership), and the right came from NAPA. Both were installed by the same guy. It'll be interesting to see which side goes first (a couple o' hundred thousand miles from now).
dcb
Old 08-19-2004, 11:32 AM
Peach
bearings
Does this failure rate reflect an actual failure or just replacement for preventative maintenence? Damn I felt that another gray hair, no this time two.
Old 08-19-2004, 12:14 PM
mbtoloczko's Avatar
sans SVX
Both of the rear bearings on my car were roaring when I bought my car at 75K miles. Replaced both, and now up to 25K miles with no problems.
Mychailo
Visit my locker
Old 08-19-2004, 01:28 PM
n00b on demand's Avatar
97 K with original bearings and no problems. I really hope i didnt jinx myself
Old 08-19-2004, 01:29 PM
Seems that the 92 SVX's are the ones with the most problems.
Old 08-19-2004, 01:59 PM
NapaBavarian's Avatar
Good morning!
highest production in '92, more cars to go poop
.Karl.
Old 08-19-2004, 02:09 PM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
Originally posted by NapaBavarian
If ya lived in Florida you could vote 4 times, but 3 would be selected by the poll workers...
Old 08-19-2004, 03:53 PM
grnSVX96's Avatar
grnSVX96 grnSVX96 is offline
ex SVX owner - still keen tho
AT survey - Chiketd ?
I voted red 95 drivers rear bearing done, Chiketd do you dare do one the same for ATs rebuilt...
David
Dave Down Under
Old 08-19-2004, 04:41 PM
BoondockSVX
Sorta. You have to take in a few factors before you come to any conclusions... First off, 92s are most numerous. Secondly, 92s are by far the cheapest SVXs, which means a few things: 1. Younger people will be able to afford them. 2. Generally younger people are more computer savy, and are more likely to come to this website and vote in these polls.
Hence, who knows. Interesting poll, but I doubt you could come to anything conclusive.
Old 08-19-2004, 06:41 PM
immortal_suby's Avatar
Thread Killah
Just look at it percentage wise
1992 SVX w/ no bearing failure 10
1992 SVX w/ bearing failure 16
- 62% failure
1994 SVX w/ no bearing failure 2
- 33% failure
1995 SVX w/ bearing failure 5
- 83% failure
1996 SVX w/ bearing failure 2
- 67% failure
- 0% failure
A percent is a percent - so volume drops from the equation, but you still have to keep in mind most '92's will have higher miles so we will probably see more failures and I will never buy a '95 now. 83% yikes
Locker Link
2015 BRZ Limited 6MT
Old 08-19-2004, 08:15 PM
~*~JenSVX~*~'s Avatar
~*~JenSVX~*~ ~*~JenSVX~*~ is offline
J. Bond
Send a message via AIM to ~*~JenSVX~*~
Where do i vote for 92 with wheel bearings failing as we speak?
Gotta love it
Jen
J. Bond 7
1994 Laguna Blue
www.longislandsubaruclub.com
LISC member #50
Old 08-20-2004, 12:22 AM
Good morning!
Gotta love it
Jen
Go buy a Ferarri, cheaper to maintain... I've decided to get a couple hubs off another car and put fresh bearings in them and toss them in the trunk with some tools, kinda like a spare tire... That way if I ever am on a trip and they go south (while I'm headed north) I will be OKay.. sort of
I'm still trying to figure out where to store the spare traney
.Karl.
Old 08-20-2004, 12:39 AM
Da'Cheat
According to the service records for my 92, the bearings have been replaced 5 times!! All within a few thousand miles of eachother. Ill assume the tech's didnt repack the bearings with the proper grease untill the last change. Done in 1999. This set is holding strong as of right now. *looks for some wood to nock on.*
The fact that the previous owner lived in Tahoe and commuted into Reno twice a day could have had somthin to do with it. Twisty mountain roads at high speeds can do that to a car *and its brakes*
Old 08-20-2004, 02:19 AM
I voted for a bearing changed in my 92, although it is technically a '91 Japan car. Moot point though.
It had very low kms when I bought it, and I have replaced the r r bearing two years and many miles ago. Been good since, I gave the mechanic stacks of info on how to do it and why replacements fail. Guess he did a good job.
Knock on wood.
Old 08-20-2004, 10:50 AM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
Re: AT survey - Chiketd ?
Now that would be a depressing thread indeed!
-Chike
2006 Steel Gray WRX TR (sold)
