"chonk" going into 2nd gear
The owner of a FWD 94 L I'm considering buying says that the car makes a slight "chonk" going into 2nd. He's had the car for 3 years (or for 38k miles), and he says it has always done that since he bought it. Is this a sign of a looming transmission problem?
Probably just a worn mount. Does the power light flash or come on at startup?
I don't know. I'll have to contact the seller. (He's not local to me.)
David,
The owner said, "yes, it has done that ever since ive owned the car. i believe it flashes 16 times." But he also said he had the transmission mount replaced just 2.5 years ago. |
I believe it's a combination of 2 things:
- the transmission mount is worn out - the resistor that helps control transmission line pressure is not working and causing full line pressure. This is most noticable on the 1-2 shift. The hard shift combined with the worn mount is what's causing the noise. You'll get a similar noise either shifting into reverse or stepping on the gas while in reverse.
Thanks, David. Is that expensive to fix? I'll be looking at the car tomorrow morning.
Hey David, My tranny shifts fine except as you said the 1st to 2nd shift... Where is said resistor and Is it something I can replace without selling a kidney? Thanks, Daniel
Insert Witty Quip Here... No more subie Current Cars: 96 Chevy Caprice Impala SS clone 93 Chevy Full-size blazer Soon: 2002 Honda CBR 954RR |
do you happen to know the price for the Transmission Mount? I'd Like to correct this before it causes any problems... Also, is it normal NOT to do the hard shift "clunk" when rappidly accelerating? I hit the gas harder then normal to get on the freeway, pass, etc.. and it doesn't do the clunk, just at slower speed shifts...
-Roger H. | Website - nsm484.com | Facebook - Roger Harvey | Twitter - nsm484 | Personal Locker 2002 Mitsubishi Lancer OZ Rally [Nori] 1996 LSi Polo Green [Calista] - 18" Konig Incident's - Lived for awhile Now Selling 1992 LSL Dark Teal [Yori] (Rear Ended, Donor to Calista, and now gone) 1992 LSL Ebony Mica (Sold to svxcuseme) |
Well if the power light comes on then goes out that's normal. If it didn't come on then the bulb is blown or removed which usually will indicate that there is a code that the previous owner was hiding.
Flashing 16 times on startup means there is a code and diagnostics must be performed to determine what the code is.
