water temp sensor
okay well i've had this problem with a tricky check engine light for about the past year. problem is it would come and go but never set long enough to run the self diagnosis and get some fault codes. last week that changed and it stayed lit every time i drove. i ran the test and it failed for the throttle position sensor and the water temp sensor. made sense since the idle would be rough when i first started up and for the first few minutes of driving the engine would be slow responding to the gas. anyway, i began with the throttle sensor. rather than paying $155 for a new one i went to radio shack and bought a five dollar can of electrical contact cleaner and to my surprise it worked. thanks for all the great info on here by the way.....marking the sensor before i took it off and especially about the small hole in the bottom to spray the cleaner without taking it apart. i thought i was in the clear...the light was out. however this week it's back again...on and off. the good thing is that it is throwing a code up....the water temp sensor. i looked on subaruparts.com and saw the part but was a little confused as to where it is. since it's fairly cheap i just want to replace it. does anyone know where exactly it's located and how hard it is to replace. mind you i have gone tow to toe with the pcv in the past and survived...just wanted to know if there's any tips.
thanks in advance for the help. the only thing i love more than my svx is this site!! |
Welcome to the site. I hope someone can help you with your question. Good luck.
go here to download a PDF file that describes where the sensor is located and how to test with a VOM. file size is about 450KBytes, and is provided as a service of a feloow forum member.
http://reaper450128.homeftp.net/pdfs..._AUOTMATIC.PDF |
temp SENSOR
This is probably the easiest thing to replace on an SVX ! On the driver side of engine, just sitting at rear of intake manifold. The previous photo should allow you to easily identify part.
water temp sensor
thanks for the info guys. actually just before i read the replies i took a good look under the hood, put two and two together and figured it was the sensor sticking out of the water pipe. thanks for the clarification though james cause even though i thought that might be it, it just seemed to simple a fix for the svx. anyway, i ordered a new one online and hopefully it does it.
thanks again all!!! |
