not a good day
Ok so after questioning the left and right pulling on my steering in another thread i was given the idea to put my car on gravel and spin the tires. In fact only the front ones dug in. So according to that post my transfer clutch is gone. Is this a given?
I have no trouble with the driving and the only time it really pulls like that is high way driving. I can be going straight and it will pull that way. Well if this is the transfer clutch then i guess i might as well go ahead and do the 4.44 swap if it turns out to be possible. So what if any transmission would be a direct swap with a final drive of 4.44? Or does anyone know if the one from a forester would in fact not work with the tcu given that is has a different diff.? This car will be the end of me. |
Wow, what a leap.
The transfer case can be fixed without transmission removal. Diff replacement will require R&R, then you still have to fix the transfer case issue. |
I wanted to do the swap anyway, i figure this might be my ticket. But i need lots of info that i cant find anywhere. |
forester driveline
i believe 01 or 02 on they had lsd rear if you get the entire thing, trans and rear end it should bolt straight up if you go with an older forester transmission you can get the diff and have them rebuild the rear end with different ring and pinion i recomend describing it as that instead of trying to explain what your doing just say that you need a rear differential rebuilt with different gears in it they'll understand much better
SV What? |
The transfer clutch, once you source the part, is butt-simple to replace. The 4.44 differential swap of course won't fix the transfer clutch problem, and won't really make replacing it significantly easier. Swapping differentials requires pulling the whole transmission and a lot of other dilly-dallying. The transfer clutch just requires removing the tail of the tranny; pop the part out - put in a new one.
It don't mean "Rest and Relaxation" for sure! R&R in "autospeak" is "Removal and Replacement."
ok so I see my problem of not getting to the point. Well lets forget the 4.44 gearing for now and just stick with the transfer clutch for this thread. We put it up in the air today and the back tires sure enough were spinning. They were noticibally slower than the front though. I guess this is because of the power split?? Also there was a horrible grinding noise coming from beneath the rear of the car. Is it possible that the clutch is just going bad and not actually dead yet? This sound does not happen when i am driving. |
There has been a few that this has happend to lately. It is caused by the transfer clutch not taking up instantly when the front spins, by the time it comes on the front are spinning hard so the shock of the clutch engaging breaks the basket off. This problem won't occur in the Euro VTD version. Harvey.
oab_au is exactly right about what's wrong. As for why it broke, his explaination is as good as any. Personally, I think the design of the clutch basket is horrible and I blame the design solely for the failure of the part - not abuse by the driver or any other fault of the transmission or controller.
More pictures for the curious. Here's what the broken part looks like: |
so is this something i just need to plan on fixing like every month or what??? There has to be something i can do or get done to help at least delay the problem??
thanks for the help |
But it's certainly not something that's going to break 'every month.' I've only seen it happen a couple of times so far. Once was Harvey's car and...wait...have we had any other confirmed cases? Oh, and if the clutch basket is broken, and you don't fix it, then you may or may not be distributing more and more metal filings throughout the tranny. Tough to say, but I wouldn't want the reduction gears (which drive the front wheels and so happen to be in the same cavity) chewing on the broken bits anyway. I don't even know how much the reduction gears would eventually cost to replace (subaruparts.com doesn't list a price), but I bet at that point you'd be better off replacing the entire tranny. Edit: By the way, this thread totally belongs in Tech Q&A. I'm moving it there now, but please post in the correct forums in the future. Thanks.
2005 RX-8 Grand Touring 2005 Outback 2002 Mercedes-Benz E320 wagon END OF LINE Last edited by Mr. Pockets; 03-11-2004 at 10:39 AM. |
sorry about the wrong forum
anyway thanks for the help. Its just frustrating when everything starts breaking at once |
...I... ...know it. But what a special car it is when it all works. Good luck, man. Let us know what happens.
