Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania
Old 10-12-2004, 08:01 PM
dragon8504 dragon8504 is offline
Send a message via AIM to dragon8504
Widest tires on SVX?
what are the widest rims that the SVX can take stock and also same just with a little mod?
Old 10-12-2004, 08:26 PM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
Svxfiles' son Nick (boxer6) has a '96 LSi with stock 16x7.5" rims running 245/45 sized tires. That's the largest I've heard of on stock rims...
Longassname has some custom 18" rims and runs 255 sized tires front and back.
-Chike
2006 Steel Gray WRX TR (sold)
Old 10-14-2004, 04:24 PM
cxt2001 cxt2001 is offline
Debo
Send a message via AIM to cxt2001
Ive seen pictures of a member on here with like 18X10's!!!! I think those were like the rear....
"DeBo"
Old 10-14-2004, 04:27 PM
Debo
here's a pic :
http://www.subaru-svx.net/photos/fil..._Man/10315.jpg
his name is Turbo_ SVX_Man
Don't know if he is still a member though.
"DeBo"
Old 10-14-2004, 08:23 PM
Chiketkd's Avatar
Damn! Those wheels/tires look thick!
That picture is a walking contradiction though - beautiful paint scheme w/ expensive wheels, and then the guy has some serious paint peeling off of his front bumper, and an exhaust pipe that looks like the cheap & heavy stuff used by backwoods muffler shops!!!
Old 10-15-2004, 08:12 AM
grnSVX96's Avatar
grnSVX96 grnSVX96 is offline
ex SVX owner - still keen tho
18x9s rear and 18x8s front
see my locker for red car - staggered wheels 9s rear and 8s on the front ..tyre size rear is 265/35x18 and fronts are 235/40x18, offsets 35 front and 40 rear...and before someone jumps in I had camber pins installed in the rear [to reduce rubbing]... as the rear tyres' outside wall - raised writing was just catching the rubber lip on the guard, no tyre damage as such and the lettering is still there, I can still induce a bit of rub with 4 aboard and getting into it around a corner, particularly if there's a bump in the corner..still no scoring of the tyre etc...I could not imagine 10in wide on the rear..perhaps a 50+ offset ...not sure on the maths for that, but my wheel/tyre combo was the largest we could do, and in Oz I only had 2 wheel style options [for a staggered set] @ reasonable $s
see my locker also for my green car 18x7.5 all round with 235/40x18s all round ..offset 48 both ends
David
Dave Down Under
Old 10-15-2004, 02:22 PM
Chiketkd's Avatar
You definitely have some wide rubber on your car David!
-Chike
Old 10-15-2004, 03:37 PM
grnSVX96's Avatar
wide tyres
Chiketkd
yeah..thanks..I put a lot of effort in trying to get the widest combo on her, i went 18s on my green car first and then went all out on my red car...with the stainless steel lip on the rims...and the wider wheel size they certainly set off the shape of the car, in motion it looks like it squats on the road and the fronts with that offset and 8s continue the line of the front fender crease out and to the ground, and the 9s on the back start to fill the push out of the rear fender nicely...chunky and tuff !!
dave
Dave Down Under
Old 10-15-2004, 04:15 PM
Chiketkd's Avatar
Thumbs up Re: wide tyres
Originally posted by grnSVX96
chunky and tuff !!
I was thinking more along the lines of sexy and svelte! The rims really set the car off! Looks like a Car Show beauty!!!
-Chike
Old 10-24-2004, 02:09 PM
Paisan Paisan is offline
Send a message via AIM to Paisan Send a message via Yahoo to Paisan
I run 245-45-16 on my SVX.
-mike
'14 Touareg TDi | '04 Nissan Armada LE | '14 BRZ
http://AZPInstalls.com
Old 10-25-2004, 02:15 PM
ThetaReactor
I've got 235/45-17s, but it looks like they're rubbing in the back. The wheels are damn nice, but the offset seems to be insufficient. They're sticking out and rubbing the inside of the fender whenever you shift weight to the rear. 40mm offset, I believe.
Old 10-26-2004, 12:02 PM
yup you need 48-53mm offset.
-mike
