Old 01-28-2011, 07:13 PM
Heli-Mech Heli-Mech is offline
Checking CELS and the light is on solid?
After my alternator shorted out I swapped on a replacement and it is running fine again, this alt only puts out 13.4v. I went for a test drive and had the CEL come on.
-I grounded the CEL wire, and instead of blinking a code it stays on steady??
-I shut the car off, started it back up and no more CEL?
-check for codes again and the light stays on steady?
Strange....
any ideas?
Old 01-28-2011, 08:21 PM
Re: Checking CELS and the light is on solid?
swapped out the ecu for my spare. The ecu is damaged. Must have been a short in the wiring, either in the alternator or the harness i made for the fan. Either way the ecu is cooked, car will run and drive fine on it but not throw or show any codes.
Old 01-28-2011, 09:07 PM
Ian,
Did that ECU arrive yet?
Old 01-28-2011, 09:39 PM
Yeah got it today. Works perfect. Thanks.
Now I don't think the ecu was the problem.
I just drove the car home from work, and it did the same thing. CEL came on after driving out onto the highway. Checked the codes and I am getting a code 55. Not sure what code 55 is, I am looking it up right now.
Old 01-28-2011, 10:13 PM
North Ursalia North Ursalia is offline
Hi Mr. Penguin!
EGR gas temp sensor from the list of codes I have
Old 01-29-2011, 08:37 AM
Where is the Egr temp sensor located? Was that a California only option?
