Old 08-31-2013, 02:53 PM
gl1674 gl1674 is offline
Box of engine parts
Have a box of engine parts left over after engine replacement.
Contains:
- set of fuel injectors on rails (engine run perfectly smooth with them)
- set of ignition coils (one has damaged insulation on wire)
- throttle body with TPS (good cond)
- IRIS valve
- master brake cylinder (probably n.g. since was sitting open)
- engine harness
- 3 camshafts, 2 camshaft sprockets
- couple of valve lifters
- steering gearbox (electronically controlled type), without the rack
- oil dipstick
- camshaft/crankshaft position sensor, don't remember which one
- couple of pulleys (one for timing belt, one for ribbed belt, both with OK bearings)
The box is heavy and I don't want to ship it. Would like someone to come in and take it all. Name your price.
