Old 08-03-2013, 11:56 AM
reberto reberto is offline
Smallcar shift kit
Took mine out of my car, so I really have no need for it anymore. $25 shipped to whomever wants it!
Old 08-10-2013, 04:55 PM
jdsnc82's Avatar
jdsnc82 jdsnc82 is offline
Re: Smallcar shift kit
Is that for the stock transmission? Or the 4.44?
Party like a rock star, rock it like a porn star, and drive it like you stole it. Life's short, live it
Old 08-12-2013, 06:33 AM
sketch sketch is offline
bump for info...
Old 08-12-2013, 08:39 AM
Old Fogey
Not meaning to step on anyone's toes here, but.....Most will agree, the Smallcar shift kit is junk. Mine went in the dumpster.
Glenn
Old 08-13-2013, 09:00 AM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Glenn
That is low
Subaru SVX for fun
Susuki SX4 for my older son
Ford Ranger for work
Old 08-13-2013, 10:31 AM
I have talked to people who like them.
Old 08-13-2013, 10:45 AM
Old Fogey
Sorry guys, loose lips etc. Mea culpa.
Glenn
Old 08-13-2013, 12:15 PM
EdWindows's Avatar
EdWindows EdWindows is offline
5spd + coilovers = win :D
Does it come with a blueprint for a custom transmission mount? If so you should scan it and post it.
1992 Dark Teal LS-L w/ 165k+ miles (traded )
Mods: Power Slot front rotors, polyurethane sway bar bushings, window scratcher fix, SPD hood struts, Outlaw Engineering phenolic spacers, Bontrager Works 22mm rear sway bar, R-134a conversion, 93 Legacy SS 5 speed swap, Ceika coilovers, ARP head studs
2001 Black Toyota Sequoia (hauler/daily)
1992 Blue Toyota Cressida (drift car)
1992 Red Toyota MR2 (weekend/track day car)
Old 08-13-2013, 12:20 PM
Glenn
I think just about everything from smallcar better belongs in a dumpster.... my $.02
Old 08-14-2013, 09:34 AM
bwb3's Avatar
bwb3 bwb3 is offline
Cruisin' in Gator Country
I think their grille looks good. Sorry if getting off topic.
Gene
Gene and Ben
Old 08-15-2013, 09:47 PM
Originally Posted by sketch View Post
bump for info...
Was fitted to my stock setup, no idea if it's cross-compatible or not
Glenn
Toes stepped on It's better than nothing to be honest.
Old 08-16-2013, 06:27 AM
processengr's Avatar
The smallcar shift kit will work with any version of 4EAT used in the SVX. I have one in our 97 stock transmissioned SVX, and had one in our previous 92 with 4.44 transmission from 97 Outback. I personally liked the way it firmed the shift from 2nd to 3rd under 1/4 throttle. It is (relative to other shift firming mods, such as the Quick change, ECUtune valve body, chipped TCU etc.) easy to buy, install and bypass/remove if you dont like it.
If you do a search, you will find plenty of discussion both pro and con.
I dont personally know of anyone who has experianced transmission failure directly because of it.
I had two different chipped TCUs in the 4.44 car, as well as the resistor from SVXfiles. I had bypassed the Smallcar kit to see the difference. I liked the shift better with than without.
Cheers! Gordon
1992 Ebony 251k 444 SOLD
1999 Silver SLK230 134k SOLD
1997 Green Outback 137k SOLD
2013 Honda Accord I4 SOLD
2015 Subaru Crosstrek 30k
2018 Tesla M3 30k
Old 08-17-2013, 12:19 AM
I have the small car shift kit in my 92 svx.
I have it set all the way on hard, I like how shifts on hard, comfort and smoothness are not my goal..
The quicker shifts from 2nd to 3rd are worth it, even it if is a piece of junk...
This is how it shifts from 2nd to 3rd in my SVX:
ECUtune v1.5 with smallcar shift kit.
Old 08-17-2013, 09:03 AM
Huskymaniac's Avatar
Uses the ignore feature
When I get a third car in the family I will probably go with the upgraded valve body from LAN. I have put it off due to having to ship back the core and the fact the car is my daily driver. I lean toward reliability verus harder shifts but I think the valve body will improve both. I don't know a lot about the small car kit as I was scared off of it early. But I doubt it would be worse that some other options which I think can't possibly be good for long term reliability. It will clearly speed up the shifts and while some will argue that it does it in a way that may be detrimental, at least energy isn't be stored up and dumped into the tranny like you get with other options out there.
Tony
Old 09-06-2013, 10:13 AM
Bump! No longer have the car, don't need it at all!
